Xiaomi Air 12 Motherboard Replacement
  1. Xiaomi Air 12 Motherboard Replacement, Rear Casing: step 1, image 1 of 1
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
    Ask FixBot
  2. Xiaomi Air 12 Motherboard Replacement: step 2, image 1 of 3 Xiaomi Air 12 Motherboard Replacement: step 2, image 2 of 3 Xiaomi Air 12 Motherboard Replacement: step 2, image 3 of 3
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
    Ask FixBot
  3. Xiaomi Air 12 Motherboard Replacement: step 3, image 1 of 2 Xiaomi Air 12 Motherboard Replacement: step 3, image 2 of 2
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
    Ask FixBot
  4. Xiaomi Air 12 Motherboard Replacement: step 4, image 1 of 3 Xiaomi Air 12 Motherboard Replacement: step 4, image 2 of 3 Xiaomi Air 12 Motherboard Replacement: step 4, image 3 of 3
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
    Ask FixBot
  5. Xiaomi Air 12 Motherboard Replacement: step 5, image 1 of 2 Xiaomi Air 12 Motherboard Replacement: step 5, image 2 of 2
    • Remove the back of the laptop by gently lifting the casing upwards.
    Ask FixBot
  6. Xiaomi Air 12 Motherboard Replacement, SSD: step 6, image 1 of 2 Xiaomi Air 12 Motherboard Replacement, SSD: step 6, image 2 of 2
    • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
    Ask FixBot
  7. Xiaomi Air 12 Motherboard Replacement: step 7, image 1 of 2 Xiaomi Air 12 Motherboard Replacement: step 7, image 2 of 2
    • Remove the 1.5mm screw using the JIS #00 screwdriver.
    Ask FixBot
  8. Xiaomi Air 12 Motherboard Replacement: step 8, image 1 of 2 Xiaomi Air 12 Motherboard Replacement: step 8, image 2 of 2
    • Lift the SSD up from the device and gently pull the SSD from the laptop.
    Ask FixBot
  9. Xiaomi Air 12 Motherboard Replacement, Battery: step 9, image 1 of 1
    • Detach the red wire from the tabs on the perimeter of the metal bracket.
    Ask FixBot
  10. Xiaomi Air 12 Motherboard Replacement: step 10, image 1 of 3 Xiaomi Air 12 Motherboard Replacement: step 10, image 2 of 3 Xiaomi Air 12 Motherboard Replacement: step 10, image 3 of 3
    • Use a PH1 screwdriver to remove the five 2mm black screws.
    • Remove two silver 1mm JIS #00 screws.
    • There will be clear plastic spacers that come off with the silver screws.
    Ask FixBot
  11. Xiaomi Air 12 Motherboard Replacement: step 11, image 1 of 3 Xiaomi Air 12 Motherboard Replacement: step 11, image 2 of 3 Xiaomi Air 12 Motherboard Replacement: step 11, image 3 of 3
    • Lift the battery up and pull out from the device.
    • The metal bracket will come out with the battery.
    Ask FixBot
  12. Xiaomi Air 12 Motherboard Replacement, Motherboard: step 12, image 1 of 2 Xiaomi Air 12 Motherboard Replacement, Motherboard: step 12, image 2 of 2
    • Lift the silver connection cover next to the USB ports using the plastic opening tool and your hands.
    Ask FixBot
  13. Xiaomi Air 12 Motherboard Replacement: step 13, image 1 of 3 Xiaomi Air 12 Motherboard Replacement: step 13, image 2 of 3 Xiaomi Air 12 Motherboard Replacement: step 13, image 3 of 3
    • Remove the four ribbon cables by lifting the connector up with the plastic opening tool and pulling the ribbon cable out.
    Ask FixBot
  14. Xiaomi Air 12 Motherboard Replacement: step 14, image 1 of 3 Xiaomi Air 12 Motherboard Replacement: step 14, image 2 of 3 Xiaomi Air 12 Motherboard Replacement: step 14, image 3 of 3
    • Disconnect the gray and black wire connectors using the plastic opening tool to lift them up.
    Ask FixBot
  15. Xiaomi Air 12 Motherboard Replacement: step 15, image 1 of 2 Xiaomi Air 12 Motherboard Replacement: step 15, image 2 of 2
    • Remove the webcam connector by gently pulling the cable out by hand.
    Ask FixBot
  16. Xiaomi Air 12 Motherboard Replacement: step 16, image 1 of 2 Xiaomi Air 12 Motherboard Replacement: step 16, image 2 of 2
    • Lift the video cable on the connector using the plastic opening tool to disconnect it.
    Ask FixBot
  17. Xiaomi Air 12 Motherboard Replacement: step 17, image 1 of 2 Xiaomi Air 12 Motherboard Replacement: step 17, image 2 of 2
    • Remove the seven black 2mm screws using a PH1 screwdriver.
    Ask FixBot
  18. Xiaomi Air 12 Motherboard Replacement: step 18, image 1 of 3 Xiaomi Air 12 Motherboard Replacement: step 18, image 2 of 3 Xiaomi Air 12 Motherboard Replacement: step 18, image 3 of 3
    • Gently lift the motherboard out by hand.
    Ask FixBot
5 other people completed this guide.
Hannah Kwan
928 Reputation
5 Guides authored
Cal Poly, Team S18-G4, Livingston Spring 2018 Member of Cal Poly, Team S18-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G4
4 Members
34 Guides authored
11 Guide Comments
Where do you order a replacement?
I couldn’t find any parts for my Xiaomi air 12.
Jon Jag - Reply Share
di you get it?
zelenmix - Reply Share
Same here. Where to get motherboard to xiaomi mi 12?
imthespace - Reply Share
Did yoiu get it?
... I would like to replace but I can't find a motherboard anywhere ... can anyone help me, where to buy the board for best price?
Aljoša Jelen - Reply Share
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 98
All Time: 7,100
