Xiaomi Air 12 Battery Replacement
    1. Xiaomi Air 12 Battery Replacement, Rear Casing: step 1, image 1 of 1
      • Orient the computer so the Xiaomi logo is at the bottom of the device.
      Ask FixBot
    2. Xiaomi Air 12 Battery Replacement: step 2, image 1 of 3 Xiaomi Air 12 Battery Replacement: step 2, image 2 of 3 Xiaomi Air 12 Battery Replacement: step 2, image 3 of 3
      • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
      Ask FixBot
    3. Xiaomi Air 12 Battery Replacement: step 3, image 1 of 2 Xiaomi Air 12 Battery Replacement: step 3, image 2 of 2
      • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
      Ask FixBot
    4. Xiaomi Air 12 Battery Replacement: step 4, image 1 of 3 Xiaomi Air 12 Battery Replacement: step 4, image 2 of 3 Xiaomi Air 12 Battery Replacement: step 4, image 3 of 3
      • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
      • You will hear popping noises as you remove the cover.
      Ask FixBot
    5. Xiaomi Air 12 Battery Replacement: step 5, image 1 of 2 Xiaomi Air 12 Battery Replacement: step 5, image 2 of 2
      • Remove the back of the laptop by gently lifting the casing upwards.
      Ask FixBot
    1. Xiaomi Air 12 Battery Replacement, SSD: step 6, image 1 of 2 Xiaomi Air 12 Battery Replacement, SSD: step 6, image 2 of 2
      • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
      Ask FixBot
    2. Xiaomi Air 12 Battery Replacement: step 7, image 1 of 2 Xiaomi Air 12 Battery Replacement: step 7, image 2 of 2
      • Remove the 1.5mm screw using the JIS #00 screwdriver.
      Ask FixBot
    3. Xiaomi Air 12 Battery Replacement: step 8, image 1 of 2 Xiaomi Air 12 Battery Replacement: step 8, image 2 of 2
      • Lift the SSD up from the device and gently pull the SSD from the laptop.
      Ask FixBot
    1. Xiaomi Air 12 Battery Replacement, Battery: step 9, image 1 of 1
      • Detach the red wire from the tabs on the perimeter of the metal bracket.
      Ask FixBot
    2. Xiaomi Air 12 Battery Replacement: step 10, image 1 of 3 Xiaomi Air 12 Battery Replacement: step 10, image 2 of 3 Xiaomi Air 12 Battery Replacement: step 10, image 3 of 3
      • Use a PH1 screwdriver to remove the five 2mm black screws.
      • Remove two silver 1mm JIS #00 screws.
      • There will be clear plastic spacers that come off with the silver screws.
      Ask FixBot
    3. Xiaomi Air 12 Battery Replacement: step 11, image 1 of 3 Xiaomi Air 12 Battery Replacement: step 11, image 2 of 3 Xiaomi Air 12 Battery Replacement: step 11, image 3 of 3
      • Lift the battery up and pull out from the device.
      • The metal bracket will come out with the battery.
      Ask FixBot
11 other people completed this guide.
Hannah Kwan
928 Reputation
5 Guides authored
Cal Poly, Team S18-G4, Livingston Spring 2018 Member of Cal Poly, Team S18-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G4
4 Members
72 Guides authored
6 Guide Comments
I have a problem, the battery do not really charge, 100% is reach in few minutes, and it works less than 15 minutes on battery. Is anybody have a solution ? Bios update maybe ?
Migwell2 - Reply Share
I got to pull out my bloated battery…. Though it could work with just the charger on stand by but it did not… Anyone knows where I can purchase new battery? Can't bring it to the shop because of quarantine but need to work from home.
Roma Monica Desunia - Reply Share
I removed the bloated battery too. It can’t power on properly. The power light just just on and off around every 5 seconds. Is yours the same?
sdot - Reply Share
after I change the battery it always says plugged in not charge, anyone has the same issue?
Anthony Jethro Lieander - Reply Share
Hi. There is no page for keyboard replacement so I'm asking my question here: how can I find a keyboard replacement for my mi 12.5 notebook? Only two buttons do not work.
Hamed Mirrezaee - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 116
All Time: 13,441
