Xelio P900A-BK Front Facing Camera Replacement
  1. Xelio P900A-BK Front Facing Camera Replacement, Front Facing Camera: step 1, image 1 of 1
    • Remove the two 5.4mm bottom screws.
    • Set aside.
    Ask FixBot
  2. Xelio P900A-BK Front Facing Camera Replacement: step 2, image 1 of 3 Xelio P900A-BK Front Facing Camera Replacement: step 2, image 2 of 3 Xelio P900A-BK Front Facing Camera Replacement: step 2, image 3 of 3
    • Insert a plastic opening tool between the screen and the rear case and carefully pry the tablet open.
    • Gently work your way around the entire tablet and do not force the case open prematurely.
    • You will hear the plastic latches pop free.
    Ask FixBot
  3. Xelio P900A-BK Front Facing Camera Replacement: step 3, image 1 of 1
    • Remove the connection between the camera and the motherboard.
    • Open the black ribbon holder then remove the ribbon from its connection.
    Ask FixBot
  4. Xelio P900A-BK Front Facing Camera Replacement: step 4, image 1 of 1
    • Remove the tape covering the front facing camera entirely to expose one of the motherboard screws.
    Ask FixBot
  5. Xelio P900A-BK Front Facing Camera Replacement: step 5, image 1 of 3 Xelio P900A-BK Front Facing Camera Replacement: step 5, image 2 of 3 Xelio P900A-BK Front Facing Camera Replacement: step 5, image 3 of 3
    • Use the smaller plastic opening tool to remove the camera from its socket.
    Ask FixBot
Marcus Nelson
307 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 10
All Time: 300
