Xelio P1001A-BK Battery Pack Replacement
  1. Xelio P1001A-BK Battery Pack Replacement, Back Cover: step 1, image 1 of 2 Xelio P1001A-BK Battery Pack Replacement, Back Cover: step 1, image 2 of 2
    • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
    Ask FixBot
  2. Xelio P1001A-BK Battery Pack Replacement: step 2, image 1 of 2 Xelio P1001A-BK Battery Pack Replacement: step 2, image 2 of 2
    • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
    • There are four securing tabs located on each long side.
    • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
    Ask FixBot
  3. Xelio P1001A-BK Battery Pack Replacement, Battery Pack: step 3, image 1 of 2 Xelio P1001A-BK Battery Pack Replacement, Battery Pack: step 3, image 2 of 2
    • De-solder the two wires that connect the battery pack to the motherboard using a needle-nose plier and a soldering iron.
    • Wrap the exposed end of the black negative wire with electrical tape.
    Ask FixBot
  4. Xelio P1001A-BK Battery Pack Replacement: step 4, image 1 of 1
    • Trace the outline of the battery pack on the screen back shield with a black Sharpie marker.
    • This will aid in positioning the new battery pack.
    Ask FixBot
  5. Xelio P1001A-BK Battery Pack Replacement: step 5, image 1 of 1
    • WARNING: Never use a knife or sharp object around a battery. Puncturing a battery may potentially cause a fire.
    • Carefully slide a spudger under the adhesive pads in between the battery pack and the screen back shield.
    • Remove the battery pack.
    • Avoid bending the battery pack.
    Ask FixBot
  6. Xelio P1001A-BK Battery Pack Replacement: step 6, image 1 of 1
    • Apply a small amount of silicon glue to the new battery on the side it will touch the screen back shield.
    • Place the battery pack on the screen back shield inside the outline.
    Ask FixBot
  7. Xelio P1001A-BK Battery Pack Replacement: step 7, image 1 of 2 Xelio P1001A-BK Battery Pack Replacement: step 7, image 2 of 2
    • Solder the red battery wire to the point labeled BATT +, and the black battery wire to the point BATT -.
    • If the wire ends are not exposed, strip 3mm of insulation from the end using a wire stripper. Start with the black negative wire and wrap the exposed ends with electrical tape.
    Ask FixBot
Michael Case
110 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 42
All Time: 534
