Shop the Holiday Gift Guide
Xelio P1001A-BK Back Cover Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
79
All Time:
770
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
Removing the back cover of the Xelio P1001A-BK tablet is fairly simple and straightforward.
There are four securing tabs along both long sides of the tablet shells which are disengaged by gently prying them apart with an opening tool. The speakers reside in two housings on the back shell half and connect to the motherboard with two very thin wires each. The tablet speakers have magnets on their backs which should make them stick to the metal shell protecting the back of the screen. However, if the speakers stay attached to the back shell half, gently pry them out of the sockets before completely separating the shell halves.
Tools
    1. Xelio P1001A-BK Back Cover Replacement, Back Cover: step 1, image 1 of 2 Xelio P1001A-BK Back Cover Replacement, Back Cover: step 1, image 2 of 2
      • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
      Ask FixBot
    2. Xelio P1001A-BK Back Cover Replacement: step 2, image 1 of 2 Xelio P1001A-BK Back Cover Replacement: step 2, image 2 of 2
      • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
      • There are four securing tabs located on each long side.
      • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
      Ask FixBot
Author
with
Josh Saenz
316 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 79
All Time: 770
