Xbox Series X Fan Replacement
    1. Xbox Series X Fan Replacement, Uncover the back panel screws: step 1, image 1 of 2 Xbox Series X Fan Replacement, Uncover the back panel screws: step 1, image 2 of 2
      • Before you begin, completely power down and unplug all cables from your console.
      • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
      Ask FixBot
    2. Xbox Series X Fan Replacement: step 2, image 1 of 3 Xbox Series X Fan Replacement: step 2, image 2 of 3 Xbox Series X Fan Replacement: step 2, image 3 of 3
      • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
      • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
      • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
      • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
      Ask FixBot
    3. Xbox Series X Fan Replacement, Remove the back panel screws: step 3, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
      Ask FixBot
    4. Xbox Series X Fan Replacement, Unclip the back panel: step 4, image 1 of 3 Xbox Series X Fan Replacement, Unclip the back panel: step 4, image 2 of 3 Xbox Series X Fan Replacement, Unclip the back panel: step 4, image 3 of 3
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
      • Pry up the back panel to release it from the locking clips.
      Ask FixBot
    5. Xbox Series X Fan Replacement: step 5, image 1 of 2 Xbox Series X Fan Replacement: step 5, image 2 of 2
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
      Ask FixBot
    6. Xbox Series X Fan Replacement, Remove the back panel: step 6, image 1 of 3 Xbox Series X Fan Replacement, Remove the back panel: step 6, image 2 of 3 Xbox Series X Fan Replacement, Remove the back panel: step 6, image 3 of 3
      • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
      • During reassembly, press along the edges of the back panel to snap it into place.
      Ask FixBot
    7. Xbox Series X Fan Replacement: step 7, image 1 of 3 Xbox Series X Fan Replacement: step 7, image 2 of 3 Xbox Series X Fan Replacement: step 7, image 3 of 3
      • The back panel slots into a gap at the top of the shell.
      • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
      • Remove the back panel.
      Ask FixBot
    1. Xbox Series X Fan Replacement, Remove the fan screws: step 8, image 1 of 1
      • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
      • One 10.5 mm pancake screw
      • Two 8.8 mm screws
      Ask FixBot
    2. Xbox Series X Fan Replacement, Disconnect the fan cable: step 9, image 1 of 3 Xbox Series X Fan Replacement, Disconnect the fan cable: step 9, image 2 of 3 Xbox Series X Fan Replacement, Disconnect the fan cable: step 9, image 3 of 3
      Buy
      • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
      • Always pull cables by their connectors and not the wires themselves.
      • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
      Ask FixBot
    3. Xbox Series X Fan Replacement, Remove the fan: step 10, image 1 of 2 Xbox Series X Fan Replacement, Remove the fan: step 10, image 2 of 2
      • Slide the fan out of its slot to remove it.
      • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
      • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
37 other people completed this guide.
Carsten Frauenheim
171,545 Reputation
441 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
1 Guide Comment
Thank you for the support! I picked up the "Essential Electronics" and it provided all i needed. Excellent tool kit!
Modesto Delvalle Jr - Reply Share
Past 24 Hours: 35
Past 7 Days: 240
Past 30 Days: 1,153
All Time: 67,003
