Xbox Series X (Digital Edition) Power Button Board Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
42
Past 30 Days:
164
All Time:
892
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the power button board in your Xbox Series X (Digital Edition) gaming console.
If your power button is sticking or isn't clicking, you may need to replace the power button board. If your Xbox Series X isn't turning on, you may need to replace the power supply.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing your console.
Parts
Tools
    1. Xbox Series X (Digital Edition) Power Button Board Replacement, Uncover the back panel screws: step 1, image 1 of 2 Xbox Series X (Digital Edition) Power Button Board Replacement, Uncover the back panel screws: step 1, image 2 of 2
      • Before you begin, completely power down and unplug all cables from your console.
      • Two stickers cover the back panel screws. You can remove the stickers without heating them, though it makes them much easier to remove cleanly.
      • Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
      • Alternatively, you can use a hair dryer to heat the sticker.
      Ask FixBot
    2. Xbox Series X (Digital Edition) Power Button Board Replacement: step 2, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement: step 2, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement: step 2, image 3 of 3
      • Use a pair of angled tweezers to remove the sticker hiding the first screw on the back panel, near the base.
      Ask FixBot
    3. Xbox Series X (Digital Edition) Power Button Board Replacement: step 3, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement: step 3, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement: step 3, image 3 of 3
      • Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
      Ask FixBot
    4. Xbox Series X (Digital Edition) Power Button Board Replacement: step 4, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement: step 4, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement: step 4, image 3 of 3
      • Use the flat end of a spudger to scrape up a corner of the larger sticker until you can grip it with a pair of blunt tweezers.
      • Use blunt tweezers to peel back the sticker to reveal the second screw.
      • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
      • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
      Ask FixBot
    5. Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the back panel screws: step 5, image 1 of 2 Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the back panel screws: step 5, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
      • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
      Ask FixBot
    6. Xbox Series X (Digital Edition) Power Button Board Replacement, Unclip the back panel: step 6, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Unclip the back panel: step 6, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Unclip the back panel: step 6, image 3 of 3
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
      • Pry up the back panel to release it from the locking clips.
      Ask FixBot
    7. Xbox Series X (Digital Edition) Power Button Board Replacement: step 7, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement: step 7, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement: step 7, image 3 of 3
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
      Ask FixBot
    8. Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the back panel: step 8, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the back panel: step 8, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the back panel: step 8, image 3 of 3
      • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
      • During reassembly, press along the edges of the back panel to snap it into place.
      Ask FixBot
    9. Xbox Series X (Digital Edition) Power Button Board Replacement: step 9, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement: step 9, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement: step 9, image 3 of 3
      • The back panel slots into a gap at the top of the shell.
      • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
      • Remove the back panel.
      Ask FixBot
    1. Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the fan screws: step 10, image 1 of 2 Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the fan screws: step 10, image 2 of 2
      • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
      • One 10.3 mm‑long pancake screw
      • Two 9 mm‑long screws
      Ask FixBot
    2. Xbox Series X (Digital Edition) Power Button Board Replacement, Disconnect the fan cable: step 11, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Disconnect the fan cable: step 11, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Disconnect the fan cable: step 11, image 3 of 3
      • Use your fingernails or a pair of angled tweezers to firmly grip the edges of the fan cable connector.
      • Grip your tweezers close the connector to get a better grip.
      • Pull the connector straight out of the socket to disconnect it.
      • If you're having trouble, gently rock the connector side to side to loosen it.
      • Always pull cables by their connectors and not the wires themselves.
      • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
      Ask FixBot
    3. Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the fan: step 12, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the fan: step 12, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the fan: step 12, image 3 of 3
      Dust Blower
      $19.99
      Buy
      • Slide the fan out of its slot to remove it.
      • During reassembly:
      • Before installing the fan, make sure it's clean! Use a dust blower or compressed air to blow off any dust or debris, and wipe the fan clean with a clean cloth.
      • Use a finger to keep the fan blades steady—it makes them easier to clean.
      • Note that the fan can only be installed one way—make sure Master Chief is facing you.
      Ask FixBot
    1. Xbox Series X (Digital Edition) Power Button Board Replacement, Unlatch the base: step 13, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Unlatch the base: step 13, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Unlatch the base: step 13, image 3 of 3
      • Use the flat end of a spudger to pry up the locking tab holding the base to the shell.
      • Keep the locking tab held open for the next step.
      Ask FixBot
    2. Xbox Series X (Digital Edition) Power Button Board Replacement, Twist and remove the base: step 14, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Twist and remove the base: step 14, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Twist and remove the base: step 14, image 3 of 3
      • With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
      • Remove the base.
      • During reassembly, put the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
      • When locked in place, the Hello from Seattle line will be parallel with the device's sides.
      Ask FixBot
    1. Xbox Series X (Digital Edition) Power Button Board Replacement, Disconnect the USB port cable: step 15, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Disconnect the USB port cable: step 15, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Disconnect the USB port cable: step 15, image 3 of 3
      • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
      • Use a spudger to flip open the metal locking tab on the USB port ribbon cable.
      • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
      Ask FixBot
    2. Xbox Series X (Digital Edition) Power Button Board Replacement, Heat the USB port cable: step 16, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Heat the USB port cable: step 16, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Heat the USB port cable: step 16, image 3 of 3
      • The USB port cable is secured to the chassis with two pieces of mild adhesive.
      • Use an iOpener or a hair dryer to heat the USB port cable.
      Ask FixBot
    3. Xbox Series X (Digital Edition) Power Button Board Replacement, Detach the USB port cable: step 17, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Detach the USB port cable: step 17, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Detach the USB port cable: step 17, image 3 of 3
      Tesa 61395 Tape
      $2.95
      Buy
      • Slide an opening pick under the USB port cable to separate the adhesive securing it.
      • During reassembly, use thin double‑sided adhesive to secure the cable. If there's adhesive left and it's still sticky, you can reuse it. If you have a new cable, check it for pre‑installed adhesive and remove any liners.
      Ask FixBot
    4. Xbox Series X (Digital Edition) Power Button Board Replacement: step 18, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement: step 18, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement: step 18, image 3 of 3
      • Use a pair of tweezers to gently pull up on the black plastic pull tab to disconnect the USB port cable.
      • Pull only on the pull tab, not the cable itself.
      • Move the USB port cable out of the way of the chassis.
      Ask FixBot
    5. Xbox Series X (Digital Edition) Power Button Board Replacement, Disconnect the power button cable: step 19, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Disconnect the power button cable: step 19, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Disconnect the power button cable: step 19, image 3 of 3
      • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
      • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
      • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
      • During reassembly, the cable should lightly "snap" into place when inserted.
      Ask FixBot
    6. Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the chassis screws: step 20, image 1 of 2 Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the chassis screws: step 20, image 2 of 2
      • Use a T8 Torx driver to remove the three 7.4 mm‑long green screws securing the center chassis assembly to the shell.
      Ask FixBot
    7. Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the chassis: step 21, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the chassis: step 21, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the chassis: step 21, image 3 of 3
      • The center chassis assembly is aligned to the bottom of the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
      • Grip the chassis and pull it towards the top of the shell, uncoupling the guide pegs from the shell.
      • Use two hands to lift out the chassis to remove it from the shell.
      • Make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
      • Use the alignment pegs and cutouts to properly orient the chassis in the shell:
      • Two pegs on the chassis with cutouts on the bottom of the shell.
      • Three pegs in the shell with cutouts on the chassis.
      Ask FixBot
    8. Xbox Series X (Digital Edition) Power Button Board Replacement: step 22, image 1 of 2 Xbox Series X (Digital Edition) Power Button Board Replacement: step 22, image 2 of 2
      Dust Blower
      $5.99
      Buy
      • Gently place the chassis heatsink-side down on a clean work surface.
      • During reassembly, this is a good point to clean the heatsink fins of any dust, dirt, or debris that may have built up over time. Use a dust blower or compressed air to clear out the fins.
      Ask FixBot
    1. Xbox Series X (Digital Edition) Power Button Board Replacement, Separate the power button cable: step 23, image 1 of 2 Xbox Series X (Digital Edition) Power Button Board Replacement, Separate the power button cable: step 23, image 2 of 2
      • The power button cable is adhered to the shell with pieces of mild adhesive.
      • Use an iOpener or a hair dryer to heat the power button cable.
      Ask FixBot
    2. Xbox Series X (Digital Edition) Power Button Board Replacement: step 24, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement: step 24, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement: step 24, image 3 of 3
      Tesa 61395 Tape
      $2.95
      Buy
      • Be very careful when lifting the cable where it connects to the board. Peel gently, and slide an opening pick under the cable if you're having trouble separating the adhesive.
      • Peel up the power button cable to fully separate it from the shell.
      Ask FixBot
    3. Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the power button board screw: step 25, image 1 of 2 Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the power button board screw: step 25, image 2 of 2
      • Use a T8 Torx driver to remove the 5.5 mm‑long screw securing the power button board.
      Ask FixBot
    4. Xbox Series X (Digital Edition) Power Button Board Replacement, Remove the power button board: step 26, image 1 of 1
      • Remove the power button board.
      Ask FixBot
    1. Xbox Series X (Digital Edition) Power Button Board Replacement, Separate the cable adhesive: step 27, image 1 of 2 Xbox Series X (Digital Edition) Power Button Board Replacement, Separate the cable adhesive: step 27, image 2 of 2
      • Check if your replacement power button board comes with a cable. If it doesn't, follow the next three steps to remove and transfer the original cable.
      • The power button cable is secured to the board with a piece of mild adhesive.
      • Use an iOpener or a hair dryer to heat the cable next to its connector on the board.
      Ask FixBot
    2. Xbox Series X (Digital Edition) Power Button Board Replacement: step 28, image 1 of 2 Xbox Series X (Digital Edition) Power Button Board Replacement: step 28, image 2 of 2
      • Gently slide an opening pick under the cable to separate the adhesive securing it.
      Ask FixBot
    3. Xbox Series X (Digital Edition) Power Button Board Replacement, Disconnect the power button cable: step 29, image 1 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Disconnect the power button cable: step 29, image 2 of 3 Xbox Series X (Digital Edition) Power Button Board Replacement, Disconnect the power button cable: step 29, image 3 of 3
      • Use the pointed end of a spudger to depress the metal tab on the power button cable's board connector.
      • With the metal tab depressed, use a pair of tweezers to grip the plastic pull tab and slide the cable out of its socket.
      Ask FixBot
Spencer Day
207,682 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
1 Guide Comment
Where can I get the board?
Virgil Abner - Reply Share
Past 24 Hours: 5
Past 7 Days: 42
Past 30 Days: 164
All Time: 892
