Xbox Series X (Digital Edition) Back Panel Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
24
Past 30 Days:
116
All Time:
1,342
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove or replace the back panel on your Xbox Series X (Digital Edition) gaming console.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing your console.
Parts
Tools
    1. Xbox Series X (Digital Edition) Back Panel Replacement, Uncover the back panel screws: step 1, image 1 of 2 Xbox Series X (Digital Edition) Back Panel Replacement, Uncover the back panel screws: step 1, image 2 of 2
      • Before you begin, completely power down and unplug all cables from your console.
      • Two stickers cover the back panel screws. You can remove the stickers without heating them, though it makes them much easier to remove cleanly.
      • Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
      • Alternatively, you can use a hair dryer to heat the sticker.
      Ask FixBot
    2. Xbox Series X (Digital Edition) Back Panel Replacement: step 2, image 1 of 3 Xbox Series X (Digital Edition) Back Panel Replacement: step 2, image 2 of 3 Xbox Series X (Digital Edition) Back Panel Replacement: step 2, image 3 of 3
      • Use a pair of angled tweezers to remove the sticker hiding the first screw on the back panel, near the base.
      Ask FixBot
    3. Xbox Series X (Digital Edition) Back Panel Replacement: step 3, image 1 of 3 Xbox Series X (Digital Edition) Back Panel Replacement: step 3, image 2 of 3 Xbox Series X (Digital Edition) Back Panel Replacement: step 3, image 3 of 3
      • Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
      Ask FixBot
    4. Xbox Series X (Digital Edition) Back Panel Replacement: step 4, image 1 of 3 Xbox Series X (Digital Edition) Back Panel Replacement: step 4, image 2 of 3 Xbox Series X (Digital Edition) Back Panel Replacement: step 4, image 3 of 3
      • Use the flat end of a spudger to scrape up a corner of the larger sticker until you can grip it with a pair of blunt tweezers.
      • Use blunt tweezers to peel back the sticker to reveal the second screw.
      • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
      • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
      Ask FixBot
    5. Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel screws: step 5, image 1 of 2 Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel screws: step 5, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
      • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
      Ask FixBot
    6. Xbox Series X (Digital Edition) Back Panel Replacement, Unclip the back panel: step 6, image 1 of 3 Xbox Series X (Digital Edition) Back Panel Replacement, Unclip the back panel: step 6, image 2 of 3 Xbox Series X (Digital Edition) Back Panel Replacement, Unclip the back panel: step 6, image 3 of 3
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
      • Pry up the back panel to release it from the locking clips.
      Ask FixBot
    7. Xbox Series X (Digital Edition) Back Panel Replacement: step 7, image 1 of 3 Xbox Series X (Digital Edition) Back Panel Replacement: step 7, image 2 of 3 Xbox Series X (Digital Edition) Back Panel Replacement: step 7, image 3 of 3
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
      Ask FixBot
    8. Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel: step 8, image 1 of 3 Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel: step 8, image 2 of 3 Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel: step 8, image 3 of 3
      • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
      • During reassembly, press along the edges of the back panel to snap it into place.
      Ask FixBot
    9. Xbox Series X (Digital Edition) Back Panel Replacement: step 9, image 1 of 3 Xbox Series X (Digital Edition) Back Panel Replacement: step 9, image 2 of 3 Xbox Series X (Digital Edition) Back Panel Replacement: step 9, image 3 of 3
      • The back panel slots into a gap at the top of the shell.
      • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
      • Remove the back panel.
      Ask FixBot
Spencer Day
207,384 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,907 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 116
All Time: 1,342
