Xbox Series X|S Controller (Model 1914) Top Housing Replacement
  1. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the battery cover: step 1, image 1 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the battery cover: step 1, image 2 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the battery cover: step 1, image 3 of 3
    • Use your fingers to slide up and remove the battery cover.
    Ask FixBot
  2. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the batteries: step 2, image 1 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the batteries: step 2, image 2 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the batteries: step 2, image 3 of 3
    • Remove the batteries.
    • When re-inserting the batteries, make sure to position them correctly, with their positive (+) and negative (–) ends matching up with the markings on the controller’s battery contacts. If your batteries are starting to corrode, replace them with new batteries.
    Ask FixBot
  3. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: step 3, image 1 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: step 3, image 2 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: step 3, image 3 of 3
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
    Ask FixBot
  4. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the left handle cover clips: step 4, image 1 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the left handle cover clips: step 4, image 2 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the left handle cover clips: step 4, image 3 of 3
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
    Ask FixBot
  5. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the left handle cover: step 5, image 1 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the left handle cover: step 5, image 2 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the left handle cover: step 5, image 3 of 3
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
    Ask FixBot
  6. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: step 6, image 1 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: step 6, image 2 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: step 6, image 3 of 3
    • Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
    Ask FixBot
  7. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the right handle cover clips: step 7, image 1 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the right handle cover clips: step 7, image 2 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the right handle cover clips: step 7, image 3 of 3
    • Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
    Ask FixBot
  8. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the right handle cover: step 8, image 1 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the right handle cover: step 8, image 2 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the right handle cover: step 8, image 3 of 3
    • Remove the right handle cover.
    • To reinstall the right handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
    Ask FixBot
  9. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Reposition the battery compartment sticker: step 9, image 1 of 2 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Reposition the battery compartment sticker: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • The sticker in the battery compartment covers a housing screw. Peel it back or pierce through it with a screwdriver.
    • Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    Ask FixBot
  10. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Unfasten the top housing: step 10, image 1 of 2 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Unfasten the top housing: step 10, image 2 of 2
    • Use a T8R Torx Security driver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
    Ask FixBot
  11. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the top housing: step 11, image 1 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the top housing: step 11, image 2 of 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the top housing: step 11, image 3 of 3
    • Lift the top housing straight up to remove it.
    Ask FixBot
6 other people completed this guide.
Manuel Haeussermann
25,919 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,624 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 81
Past 30 Days: 523
All Time: 11,210
