Xbox Series S Wi-Fi Board Replacement
    1. Xbox Series S Wi-Fi Board Replacement, Peel off the sticker coverings: step 1, image 1 of 3 Xbox Series S Wi-Fi Board Replacement, Peel off the sticker coverings: step 1, image 2 of 3 Xbox Series S Wi-Fi Board Replacement, Peel off the sticker coverings: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Before you start this guide, turn off the Xbox and unplug any cables from it.
      • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
      Ask FixBot
    2. Xbox Series S Wi-Fi Board Replacement, Remove the back panel screws: step 2, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
      Ask FixBot
    3. Xbox Series S Wi-Fi Board Replacement, Remove the bottom panel: step 3, image 1 of 3 Xbox Series S Wi-Fi Board Replacement, Remove the bottom panel: step 3, image 2 of 3 Xbox Series S Wi-Fi Board Replacement, Remove the bottom panel: step 3, image 3 of 3
      • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
      • This slides the clips out of the slots on the plastic case.
      • Lift straight up and remove the bottom panel from the plastic case.
      Ask FixBot
    4. Xbox Series S Wi-Fi Board Replacement, Remove the plastic case screws: step 4, image 1 of 1
      • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
      Ask FixBot
    5. Xbox Series S Wi-Fi Board Replacement, Remove the plastic case: step 5, image 1 of 3 Xbox Series S Wi-Fi Board Replacement, Remove the plastic case: step 5, image 2 of 3 Xbox Series S Wi-Fi Board Replacement, Remove the plastic case: step 5, image 3 of 3
      • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
      • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
      • The back panel should now settle on top of the clips on the back of the plastic case.
      • The back panel is permanently attached to the aluminum chassis.
      • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
      Ask FixBot
    6. Xbox Series S Wi-Fi Board Replacement: step 6, image 1 of 3 Xbox Series S Wi-Fi Board Replacement: step 6, image 2 of 3 Xbox Series S Wi-Fi Board Replacement: step 6, image 3 of 3
      • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
      • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
      • Remove the plastic case from the chassis.
      Ask FixBot
    1. Xbox Series S Wi-Fi Board Replacement, Remove the Wi-Fi board: step 7, image 1 of 1
      • Use a T8 Torx driver to remove the three 9.5 mm-long screws securing the Wi-Fi board to the short edge of the chassis.
      Ask FixBot
    2. Xbox Series S Wi-Fi Board Replacement: step 8, image 1 of 3 Xbox Series S Wi-Fi Board Replacement: step 8, image 2 of 3 Xbox Series S Wi-Fi Board Replacement: step 8, image 3 of 3
      • Use a spudger to pry and loosen the Wi-Fi board.
      • Do not pry from the bottom or sides of the Wi-Fi board as it may bend the connector.
      • Pull the Wi-Fi board straight out to disconnect it from the chassis.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
4 other people completed this guide.
Robert Boyd
33,544 Reputation
94 Guides authored
3 Guide Comments
Did anyone else replace the HDMI port and have it chirp then immediately shut off after the chirp? if so what was your fix or is it the APU that's fried?
Zach - Reply Share
Se puede usar la misma pieza en un xbox series s black carbon? Saludos espero su respuesta
Logan Sanchez - Reply Share
If all my controllers disconnects randomly I have to replace the wifi board or the bluetooth?
Roberto Mazza - Reply Share
Past 24 Hours: 12
Past 7 Days: 85
Past 30 Days: 346
All Time: 12,896
