Up to 20% off select tools
Xbox One X Disc Drive Replacement
Views: 47K
View statistics:
Past 24 Hours:
27
Past 7 Days:
234
Past 30 Days:
970
All Time:
47,352
Comments: 23
20 comments on steps, 3 guide comments.
Go to guide comments
Completed: 22
22 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace the disc drive (also called the optical drive) on your Xbox One X model 1787. You might do this if other troubleshooting steps don’t fix disc-reading issues.
Turn off the console and unplug any cables before beginning this guide. Follow general electrostatic discharge (ESD) safety procedures while repairing the console.
Because the disc drive’s circuit board is linked to the console’s motherboard, you will need to transfer the original board into the replacement disc drive. This will require you to de-solder and solder two wires. Follow general soldering safety guidelines such as wearing eye protection, working in a well-ventilated area, and washing your hands after with soap and water after soldering.
Video Overview
    1. Xbox One X Disc Drive Replacement, Remove the sticker: step 1, image 1 of 2 Xbox One X Disc Drive Replacement, Remove the sticker: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Before starting this guide: Turn off the device. Then, unplug any cables from the console.
      • Use blunt tweezers to peel off the sticker covering the right-side screw on the back of the console.
      Ask FixBot
    2. Xbox One X Disc Drive Replacement, Remove the external screws: step 2, image 1 of 1
      • Use a T10 Torx screwdriver to remove the two 12.6 mm–long screws located on the back of the console.
      Ask FixBot
    3. Xbox One X Disc Drive Replacement, Slide the upper case horizontally: step 3, image 1 of 2 Xbox One X Disc Drive Replacement, Slide the upper case horizontally: step 3, image 2 of 2
      • Rotate the console 90 degrees.
      • Pull the front of the upper plastic case horizontally toward the front of the console until it comes to a stop. This slides the clips out of the slots on the upper plastic case.
      Ask FixBot
    4. Xbox One X Disc Drive Replacement, Lift the upper case off the lower case: step 4, image 1 of 2 Xbox One X Disc Drive Replacement, Lift the upper case off the lower case: step 4, image 2 of 2
      • Rotate the console 90 degrees so that the back is facing you.
      • Lift up the left side of the upper plastic case (as viewed from the back of the console), stopping when it won’t lift any further.
      Ask FixBot
    5. Xbox One X Disc Drive Replacement: step 5, image 1 of 3 Xbox One X Disc Drive Replacement: step 5, image 2 of 3 Xbox One X Disc Drive Replacement: step 5, image 3 of 3
      • While continuing to hold the left side of the upper plastic case, push up on the right side to move the right-side screw boss out of the way.
      • If pushing up on the case doesn't work, try moving it in different directions until it can swing open.
      • Swing the upper plastic case open to 75 degrees.
      Ask FixBot
    6. Xbox One X Disc Drive Replacement: step 6, image 1 of 2 Xbox One X Disc Drive Replacement: step 6, image 2 of 2
      • Push the upper plastic case down and away from the console to remove it completely.
      Ask FixBot
    1. Xbox One X Disc Drive Replacement, Disconnect the ribbon cable: step 7, image 1 of 3 Xbox One X Disc Drive Replacement, Disconnect the ribbon cable: step 7, image 2 of 3 Xbox One X Disc Drive Replacement, Disconnect the ribbon cable: step 7, image 3 of 3
      • Use the pointed end of a spudger, an opening tool, or your fingernail to flip down the small, hinged locking flap on the ribbon cable ZIF connector on the front circuit board.
      Ask FixBot
    2. Xbox One X Disc Drive Replacement, Disconnect the ribbon cable: step 8, image 1 of 1
      Buy
      • Use blunt tweezers to pull the ribbon cable down out of the connector.
      Ask FixBot
    3. Xbox One X Disc Drive Replacement, Remove the front circuit board screws: step 9, image 1 of 1
      • Use a T8 Torx screwdriver to remove the three 13.3 mm screws securing the front circuit board to the upper metal case.
      Ask FixBot
    4. Xbox One X Disc Drive Replacement, Remove the front circuit board: step 10, image 1 of 2 Xbox One X Disc Drive Replacement, Remove the front circuit board: step 10, image 2 of 2
      • Pull the front circuit board straight out away from the upper metal case and set it aside.
      • Grip the board on either side of where it is plugged in to avoid bending and damaging it.
      Ask FixBot
    5. Xbox One X Disc Drive Replacement, Remove the upper metal case screws: step 11, image 1 of 1
      • Use a T10 Torx screwdriver to remove the six 47.7 mm screws securing the upper metal case to the lower plastic case.
      • Use a T8 Torx screwdriver to remove the two 7.5 mm screws securing the press connector to the upper metal case.
      Ask FixBot
    6. Xbox One X Disc Drive Replacement, Detach the press connector: step 12, image 1 of 2 Xbox One X Disc Drive Replacement, Detach the press connector: step 12, image 2 of 2
      • Insert the flat end of a spudger underneath the press connector on the side opposite of the ribbon cable.
      • Use the spudger to lift the press connector up and away from the upper metal case.
      • Don't push the spudger all the way to the socket. Prying up the socket may damage it.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    7. Xbox One X Disc Drive Replacement, Remove the lower plastic case: step 13, image 1 of 3 Xbox One X Disc Drive Replacement, Remove the lower plastic case: step 13, image 2 of 3 Xbox One X Disc Drive Replacement, Remove the lower plastic case: step 13, image 3 of 3
      • Flip the console over.
      • Hold on to the lower plastic case because it is no longer attached to the metal case.
      • Lift the lower plastic case up from the metal case and set it aside.
      Ask FixBot
    8. Xbox One X Disc Drive Replacement, Remove the lower metal case screws: step 14, image 1 of 1
      • Remove the two T10 Torx screws securing the lower metal case:
      • One 7.7 mm screw
      • One 11.4 mm screw
      Ask FixBot
    9. Xbox One X Disc Drive Replacement, Remove the lower metal case: step 15, image 1 of 1
      • Lift the lower metal case up off the upper metal case and internal components.
      • The disc drive may lift up with the lower metal case. Hold it down during this step.
      • Set the lower metal case aside.
      Ask FixBot
    1. Xbox One X Disc Drive Replacement, Unscrew the power supply: step 16, image 1 of 1
      • The disc drive is only attached to the motherboard by two cable connectors. Hold the disc drive when flipping the console over to avoid damaging it.
      • Use a T10 Torx screwdriver to remove the two 11.4 mm screws securing the power supply to the upper metal case
      Ask FixBot
    2. Xbox One X Disc Drive Replacement, Loosen the disc drive: step 17, image 1 of 2 Xbox One X Disc Drive Replacement, Loosen the disc drive: step 17, image 2 of 2
      • Lift the disc drive so that its metal tab is unhooked from the power supply.
      • The disc drive is plugged into the motherboard. Don’t bend the wires more than necessary to avoid damaging them.
      • Place the disc drive on the upper metal case so that it sits over the hard drive. You'll need enough space to unplug the power supply from the motherboard.
      Ask FixBot
    3. Xbox One X Disc Drive Replacement, Unstick the foam tape on the power supply: step 18, image 1 of 3 Xbox One X Disc Drive Replacement, Unstick the foam tape on the power supply: step 18, image 2 of 3 Xbox One X Disc Drive Replacement, Unstick the foam tape on the power supply: step 18, image 3 of 3
      • Insert the flat end of the spudger underneath the dark grey foam tape starting at the corner closest to the power supply and edge of the console.
      • Lift up the corner.
      • Slowly push the spudger through to the other side of the tape until you can see the flat end emerge.
      • Remove the spudger slowly. There are two grey cables underneath the foam tape. Try to avoid hitting them with the spudger so that you don't damage them.
      Ask FixBot
    4. Xbox One X Disc Drive Replacement, Unplug the power supply: step 19, image 1 of 2 Xbox One X Disc Drive Replacement, Unplug the power supply: step 19, image 2 of 2
      • Lift the power supply directly upward to unplug it from the motherboard.
      • Move the disc drive further away from the power supply if you need more space.
      Ask FixBot
    5. Xbox One X Disc Drive Replacement, Set the power supply to the side: step 20, image 1 of 3 Xbox One X Disc Drive Replacement, Set the power supply to the side: step 20, image 2 of 3 Xbox One X Disc Drive Replacement, Set the power supply to the side: step 20, image 3 of 3
      • After the power supply is unplugged from the motherboard, rotate and lift it away from the console.
      • The two grey cables are still attached to the console by the dark grey foam tape and the power supply socket beneath the fan case. Avoid bending the cables more than necessary to prevent damage.
      • Place the power supply so that it is sitting on its side just outside the upper metal case.
      Ask FixBot
    6. Xbox One X Disc Drive Replacement, Unplug the disc drive: step 21, image 1 of 2 Xbox One X Disc Drive Replacement, Unplug the disc drive: step 21, image 2 of 2
      • Unplug the SATA cable connecting the disc drive to the motherboard by pulling directly upward.
      Ask FixBot
    7. Xbox One X Disc Drive Replacement: step 22, image 1 of 2 Xbox One X Disc Drive Replacement: step 22, image 2 of 2
      • Unplug the bundled cable connector connecting the disc drive to the motherboard by pulling directly upward.
      Ask FixBot
    8. Xbox One X Disc Drive Replacement, Remove the disc drive: step 23, image 1 of 1
      • Lift the disc drive out of the console.
      Ask FixBot
    9. Xbox One X Disc Drive Replacement, Remove the vibration dampener: step 24, image 1 of 3 Xbox One X Disc Drive Replacement, Remove the vibration dampener: step 24, image 2 of 3 Xbox One X Disc Drive Replacement, Remove the vibration dampener: step 24, image 3 of 3
      • Slide the rubber vibration dampener off of the disc drive.
      Ask FixBot
    10. Xbox One X Disc Drive Replacement, Remove the external disc drive connectors: step 25, image 1 of 2 Xbox One X Disc Drive Replacement, Remove the external disc drive connectors: step 25, image 2 of 2
      • Unplug the bundled cable connector from the disc drive.
      Ask FixBot
    11. Xbox One X Disc Drive Replacement: step 26, image 1 of 2 Xbox One X Disc Drive Replacement: step 26, image 2 of 2
      • Unplug the SATA cable from the disc drive.
      Ask FixBot
    12. Xbox One X Disc Drive Replacement, Remove the cover: step 27, image 1 of 1
      • Use a Phillips screwdriver to remove the four 3.7 mm screws securing the disc drive cover.
      • You don't need to remove the foam covering the two right-side screws. Move the foam aside just enough to expose the screw.
      Ask FixBot
    13. Xbox One X Disc Drive Replacement: step 28, image 1 of 2 Xbox One X Disc Drive Replacement: step 28, image 2 of 2
      • Remove the cover from the disc drive.
      Ask FixBot
    14. Xbox One X Disc Drive Replacement, Disconnect the three ZIF connectors: step 29, image 1 of 2 Xbox One X Disc Drive Replacement, Disconnect the three ZIF connectors: step 29, image 2 of 2
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the large ribbon cable ZIF connector.
      Ask FixBot
    15. Xbox One X Disc Drive Replacement: step 30, image 1 of 2 Xbox One X Disc Drive Replacement: step 30, image 2 of 2
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the small ribbon cable next to the large ribbon cable ZIF connector.
      Ask FixBot
    16. Xbox One X Disc Drive Replacement: step 31, image 1 of 2 Xbox One X Disc Drive Replacement: step 31, image 2 of 2
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the long ribbon cable in the corner of the disc drive ZIF connector.
      Ask FixBot
    17. Xbox One X Disc Drive Replacement: step 32, image 1 of 3 Xbox One X Disc Drive Replacement: step 32, image 2 of 3 Xbox One X Disc Drive Replacement: step 32, image 3 of 3
      Buy
      • Use blunt tweezers to pull out each of the three ribbon cables in the direction of the cable.
      Ask FixBot
    18. Xbox One X Disc Drive Replacement, Desolder the two wires: step 33, image 1 of 2 Xbox One X Disc Drive Replacement, Desolder the two wires: step 33, image 2 of 2
      • Use a soldering iron to desolder the red wire in the corner of the disc drive circuit board.
      • Then, desolder the adjacent black wire. Use blunt tweezers to hold and pull away the wires from the circuit board.
      • Follow general soldering safety guidelines such as wearing eye protection, working in a well-ventilated area, and washing your hands with soap and water after soldering.
      • Excessive heat may damage electrical components. Don't apply the soldering iron to the board for long amounts of time.
      • When you install the original circuit board into the replacement disc drive, solder the red wire to the solder pad labeled "R." Solder the black wire to the solder pad labeled "B."
      Ask FixBot
    19. Xbox One X Disc Drive Replacement, Remove the circuit board screws: step 34, image 1 of 1
      • Use a Phillips screwdriver to remove the three 3.4 mm screws securing the circuit board to the disc drive case.
      Ask FixBot
    20. Xbox One X Disc Drive Replacement, Remove the disc drive circuit board: step 35, image 1 of 2 Xbox One X Disc Drive Replacement, Remove the disc drive circuit board: step 35, image 2 of 2
      • Lift the circuit board out of the disc drive case and transfer it to the replacement drive.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox One X Answers community for help.
22 other people completed this guide.
Author
with
Kyle Smith
53,826 Reputation
124 Guides authored
3 Guide Comments
I bought a One X for cheap and it worked but the Disc drive didn't - it couldn't pull in the discs; I opened it up, discovered that it was very dusty, cleaned that out and also cleaned the Disc drive, especially the rollers of the mechanism that pushes the disc out or pulls it in, of course also the laser lens, then reassembled it and it works absolutely fine again.
Marcel Pape - Reply Share
Ive replaced the dvd drive with mine but the game discs will not load
David Chan - Reply Share
would it work if i got the Disc drive from my old xbox one ? i think they are the same exact size though !
AbuObaid Home - Reply Share
Past 24 Hours: 27
Past 7 Days: 234
Past 30 Days: 970
All Time: 47,352
