Introduction
Go to step 1 ↓This guide will assist you in replacing your thumbstick. If you have a rogue thumbstick, you have come to the right place.
Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
Use a screwdriver and punch a hole directly in the center of the label.
Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
207 other people completed this guide.
32 Guide Comments
Is there any advice for a controller that has had this repair, but continues to drift? I have done this repair successfully many times, and now i have a controller that (with 2 different replacement parts) continues to drift.
Is there a reset or config I can do?
Can i apply 2 thumbsticks off the xbox 360 controller when i removed them?
