Xbox One Wireless Controller Model 1708 Trigger Caps Replacement
    1. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement, Trigger Caps: step 1, image 1 of 2 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement, Trigger Caps: step 1, image 2 of 2
      • Slide the battery cover out and remove it.
      • Remove the battery pack.
      Ask FixBot
    2. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 2, image 1 of 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 2, image 2 of 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 2, image 3 of 3
      • Insert a plastic opening tool between the handle and the plate.
      • Gently slide the opening tool from the top end to the bottom end of the seam to remove the plate from the handle.
      • Repeat the process with the other side plate.
      • The plate is tightly sealed on the handle, so it may be difficult to remove.
      Ask FixBot
    3. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 3, image 1 of 2 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 3, image 2 of 2
      • Remove the five 2.3mm screws on the bottom plate with a T8 Torx security Screwdriver.
      • If there is a sticker on the back, poke a hole with the screwdriver to get to the fifth screw.
      Ask FixBot
    4. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 4, image 1 of 2 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 4, image 2 of 2
      • Remove the bottom plate.
      Ask FixBot
    5. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 5, image 1 of 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 5, image 2 of 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 5, image 3 of 3
      • Carefully turn over the controller with the front plate facing you.
      • Remove the front plate.
      Ask FixBot
    6. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 6, image 1 of 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 6, image 2 of 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 6, image 3 of 3
      • Remove the two 1.7mm screws from each of the triggers with a T6 Torx screwdriver.
      • It is best to do one trigger cap replacement at a time.
      Ask FixBot
    7. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 7, image 1 of 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 7, image 2 of 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 7, image 3 of 3
      • Be careful not to let the trigger motor inside come out.
      • Lift the trigger cap off the trigger motor.
      Ask FixBot
    8. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 8, image 1 of 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 8, image 2 of 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: step 8, image 3 of 3
      • Place the new trigger cap on the trigger motor.
      • Push down the inside of the trigger cap until you hear a click.
      • Repeat step six to eight for the other trigger cap.
      Ask FixBot
To reassemble your device, follow steps 1-5 in reverse order.
20 other people completed this guide.
Lucero Cortes-Vitervo
584 Reputation
1 Guide authored
UC Davis, Team S1-G6, Andersen Winter 2020 Member of UC Davis, Team S1-G6, Andersen Winter 2020
UCD-ANDERSEN-W20S1G6
3 Members
12 Guides authored
1 Guide Comment
Et le reboitage stp non parce que je pense que ses le plus compliqué.
Yoann.cadenat - Reply Share
Past 24 Hours: 13
Past 7 Days: 94
Past 30 Days: 372
All Time: 27,825
