Xbox One Wireless Controller Model 1708 Directional Pad Replacement
    1. Xbox One Wireless Controller Model 1708 Directional Pad Replacement, Cover Plate: step 1, image 1 of 2 Xbox One Wireless Controller Model 1708 Directional Pad Replacement, Cover Plate: step 1, image 2 of 2
      • Slide the battery cover toward the top of the controller to remove it.
      • Lift up the batteries or the battery pack from the battery compartment.
      Ask FixBot
    2. Xbox One Wireless Controller Model 1708 Directional Pad Replacement: step 2, image 1 of 2 Xbox One Wireless Controller Model 1708 Directional Pad Replacement: step 2, image 2 of 2
      • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
      • Continue using the opening tool to gently pry the side plate off of the controller.
      • Repeat this process for the second side plate.
      Ask FixBot
    3. Xbox One Wireless Controller Model 1708 Directional Pad Replacement: step 3, image 1 of 1
      • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
      • Remove the five 9mm torx-9 security screws from the back of the controller.
      Ask FixBot
    4. Xbox One Wireless Controller Model 1708 Directional Pad Replacement: step 4, image 1 of 2 Xbox One Wireless Controller Model 1708 Directional Pad Replacement: step 4, image 2 of 2
      • Orient the controller so the front plate is facing up.
      • Lift the front cover off of the controller.
      Ask FixBot
    5. Xbox One Wireless Controller Model 1708 Directional Pad Replacement: step 5, image 1 of 1
      • Turn the controller face down and gently lift the rear plate.
      • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
      Ask FixBot
    6. Xbox One Wireless Controller Model 1708 Directional Pad Replacement, Tape Shock Motors in place: step 6, image 1 of 3 Xbox One Wireless Controller Model 1708 Directional Pad Replacement, Tape Shock Motors in place: step 6, image 2 of 3 Xbox One Wireless Controller Model 1708 Directional Pad Replacement, Tape Shock Motors in place: step 6, image 3 of 3
      • Tape the Rumbler/shock motors in place.
      • This will prevent the motors from falling out.
      Ask FixBot
    1. Xbox One Wireless Controller Model 1708 Directional Pad Replacement, Directional Pad: step 7, image 1 of 1
      • Turn the device over and remove the directional pad by gently pulling it away from the controller.
      Ask FixBot
26 other people completed this guide.
Dylan Gross
5,038 Reputation
4 Guides authored
Cal Poly, Team S18-G3, Forte Fall 2017 Member of Cal Poly, Team S18-G3, Forte Fall 2017
CPSU-FORTE-F17S18G3
4 Members
84 Guides authored
7 Guide Comments
Will one of the D-pads from the Xbox One controller model 1698 fit and work with the Xbox One-S controller model 1708. I have been looking all over the net for a replacement D-pad and other buttons like the RB, LB Bumper setup and I have had absolutely no luck finding replacement D-pads or other buttons specifically designed for the Xbox One-S controller. I would greatly appreciate your help.
Walter “Biggdubbya” Kloster - Reply Share
My D-pad was not working properly so I dropped drops of alcohol and other cleaners to fix the issue since the screws inside my controller were stripped and I was unable to open it and at the beginning it worked but then It started failing again so I did it again and this time the left direction is dead. I sent it to be repaired and they told it couldn't be salvaged yet they repaired the thumbsticks just to force me to pay them.
Diego Jose - Reply Share
The D-pad on our controller sticks. I disassembled the device and discovered one of the small metal pieces that are supposed to spring back after the button is pressed has been deformed. I will need new ones, but I don’t know what to call the part or where to get it, but I’m sure it’s pennies? Any suggestions? I’d add a photo if I could here.
Joseph Greer - Reply Share
Search for “Xbox One Controller Replacement D-Pad Button Metal Dome Conductive Film Sticker” on Amazon, NewEgg or Ebay. Should cost 5-10 bucks. Cheaper if you get it shipped from China, but takes forever.
Sudil Mahendra - Reply Share
I too have disassembled a controller to discover that this is the cause of the D-Pad not functioning on one side. I am however unsure of how to remove the damaged part as the guide only covers removing the D-Pad itself.
Mark Smith - Reply Share
Past 24 Hours: 6
Past 7 Days: 64
Past 30 Days: 334
All Time: 20,654
