Introduction
Go to step 1 ↓This guide will teach you how to replace the D-pad.
Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
Use a screwdriver and punch a hole directly in the center of the label.
Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
50 other people completed this guide.
7 Guide Comments
it's exactly the same like shown above :)
