Xbox One Wireless Controller 1697 Thumbstick Replacement
    1. Xbox One Wireless Controller 1697 Thumbstick  Replacement, Thumbstick: step 1, image 1 of 1
      • Slide the battery pack cover toward the top of the controller to remove it.
      • Remove batteries.
      Ask FixBot
    2. Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 2, image 1 of 2 Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 2, image 2 of 2
      • We recommend using a plastic spudger to prevent damage to your controller. However, using a metal spudger, as shown in the picture, makes the work easier.
      • Hold firmly the controller, place the spudger into the top seam of the controller and carefully work all the way to the bottom.
      • Pry the side of handle away from the controller by moving the spudger back and forth around the side handle's seam.
      • Repeat this process for both side handles.
      Ask FixBot
    3. Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 3, image 1 of 2 Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 3, image 2 of 2
      • Using the T8 Security Torxs screwdriver, remove the five 10mm screws from the back of the controller.
      • One of the screws is hidden behind the label.
      • You can punch a hole using a screwdriver or peel off the label.
      Ask FixBot
    4. Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 4, image 1 of 3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 4, image 2 of 3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 4, image 3 of 3
      • Remove the back plate.
      Ask FixBot
    5. Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 5, image 1 of 1
      • Remove the faceplate
      Ask FixBot
    6. Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 6, image 1 of 3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 6, image 2 of 3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 6, image 3 of 3
      • Select the thumbstick that you want to replace and pull it off its pole.
      Ask FixBot
30 other people completed this guide.
Emely
920 Reputation
1 Guide authored
USF Tampa, Team S9-G1, Remmell Fall 2017 Member of USF Tampa, Team S9-G1, Remmell Fall 2017
USFT-REMMELL-F17S9G1
4 Members
36 Guides authored
1 Guide Comment
Hello. I have an controller but it isn't working right. The right stick wont register when i push it down. I spilled cola on it. Any tips?
Isak - Reply Share
Past 24 Hours: 9
Past 7 Days: 40
Past 30 Days: 223
All Time: 28,326
