Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment
    1. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Change note: step 1, image 1 of 2 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Change note: step 1, image 2 of 2
      Tool used on this step:
      Essential Electronics Toolkit
      $29.95
      Buy
      • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
      • If you are interested in a refurbished kit stock levels change frequently but can be found here.
      Ask FixBot
    1. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 1): step 2, image 1 of 3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 1): step 2, image 2 of 3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 1): step 2, image 3 of 3
      • EET owners: Your kit has this bit. No purchase needed.
      • Remove the batteries from your controller (if installed).
      • Remove the screw under the battery cover label. To do this, puncture the label where it is marked and use a TR8 driver or bit to remove the screw. TIP: This acrew us generally going to be found in the center of the label - feel around with your nail if need be to find it.
      • Remove the side trim from the controller, along with the 4 TR8 screws. Set the trim and screws aside somewhere safe.
      Ask FixBot
    2. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 2): step 3, image 1 of 3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 2): step 3, image 2 of 3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 2): step 3, image 3 of 3
      iFixit Opening Tool
      $5.95
      Buy
      • Author's note: I have no intention of retaking these photos as I do not have my 1697 anymore (and avoid them when possible). I can do this with one hand, but using a pry tool in the area marked in orange makes this easier.
      • With the screws removed from the back, flip the controller to the front. Remove the front plastic cover.
      • With the front plastic cover removed, remove the back shell. A plastic pry tool can be used if it is easier.
      • Remove the shell once the battery tabs are released.
      Ask FixBot
    3. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 3): step 4, image 1 of 3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 3): step 4, image 2 of 3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 3): step 4, image 3 of 3
      iFixit Opening Tool
      $5.95
      Buy
      • Remove the power button cover from the controller. If the LB/RB assembly is separate, remove this next. A plastic pry tool can also be used.
      • Remove the wireless sync button. Place this on a bright surface to avoid misplacement.
      Ask FixBot
    4. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Cut new heatshink tubing: step 5, image 1 of 3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Cut new heatshink tubing: step 5, image 2 of 3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Cut new heatshink tubing: step 5, image 3 of 3
      Precision Utility Knife
      Buy
      • Repair one trigger at a time!
      • Before cutting the heatshrink, make TWO alignment marks (non-crossing).
      • After making alignment marks, cut the heatshrink off using a utility knife.
      • Using the old heatshrink as a reference, cut two new pieces.
      Ask FixBot
    5. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): step 6, image 1 of 3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): step 6, image 2 of 3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): step 6, image 3 of 3
      • Incorrect magnet alignment will result in LT/RT activation without human input.
      • After cutting the heatshrink tubing, do a test alignment before applying glue.
      • These controllers use double sided tape from the factory. Note the dimple side and clean the magnet and frame. Goo Gone can be used on difficult residue.
      • Once the parts are reasonably clean, do a test alignment and apply tape for final installation.
      Ask FixBot
    6. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Align the magnet and glue it in place: step 7, image 1 of 2 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Align the magnet and glue it in place: step 7, image 2 of 2
      • A controller frame may be required if done incorrectly. Verify the alignment before adding glue!
      • After verifying the alignment is correct, apply glue to the controller. It is best to let it cure for 24 hours if possible.
      Ask FixBot
    7. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Install new heatshrink tubing: step 8, image 1 of 1
      Heat Shrink Tubing Assortment
      $7.99
      Buy
      • Soft flame lighters may melt the plastic. Blue flame lighters are generally safer for this!
      • Once the glue cures, add new heatshrink tubing.
      Ask FixBot
Finish Line
9 other people completed this guide.
Nick
106,163 Reputation
72 Guides authored
5 Guide Comments
Do you know any specs on the magnet itself? I have a controller that is missing a magnet, and can’t find any information on the strength of the magnet. Without that there’s no way to get a replacement.
Eric Harper - Reply Share
same here cant find it any were
conman3609 - Reply Share
check on aliexpress they have then in stock
Noob Gamer - Reply Share
Ma gachette RT reste enfoncé c quoi le problème.
Merci d'avance
Chawki Bourokba - Reply Share
Past 24 Hours: 10
Past 7 Days: 59
Past 30 Days: 254
All Time: 27,700
