Xbox One Wireless Controller (1697 Model) D-pad Replacement
Views: 13K
View statistics:
Past 24 Hours:
5
Past 7 Days:
44
Past 30 Days:
190
All Time:
13,201
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
If your Xbox One Wireless Controller (model 1697) Directional-pad (D-pad) is not working when your thumb presses the button, then use this guide to replace the D-pad. The D-pad is the raised, “plus-sign” looking button that is located between the left and right thumb sticks that helps the user adjust the focus or other controls of a specific Xbox One game. Before removing the D-pad, make sure to power off your Xbox One controller completely.
Parts
Tools
    1. Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: step 1, image 1 of 3 Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: step 1, image 2 of 3 Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: step 1, image 3 of 3
      • Remove the side handles with the iFixit plastic opening tool by wedging it around the seam of the handles.
      • Be careful not to break the clips when removing the handles.
      Ask FixBot
    2. Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 2, image 1 of 1
      • Remove the battery cover and the batteries by sliding the cover up.
      Ask FixBot
    3. Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 3, image 1 of 1
      • Remove the two screws (four total screws) on the top and bottom of each controller handle and one screw underneath the battery pack using the T9 Torx screwdriver.
      • The screw underneath the battery pack is located under the sticker.
      Ask FixBot
    4. Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 4, image 1 of 3 Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 4, image 2 of 3 Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 4, image 3 of 3
      • Remove the front cover of the controller. using the spudger.
      Ask FixBot
    5. Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 5, image 1 of 1
      • Remove the back cover of the controller using the spudger.
      Ask FixBot
    6. Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 6, image 1 of 2 Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 6, image 2 of 2
      • Remove the metal ring surrounding the D-pad.
      Ask FixBot
    7. Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 7, image 1 of 1
      • Remove the D-pad from the device.
      Ask FixBot
13 other people completed this guide.
1 Guide Comment
Hellow mine has a problem that it doesn't work\turn on with battery or with a cable like its dead
Abdulhamid - Reply Share
Past 24 Hours: 5
Past 7 Days: 44
Past 30 Days: 190
All Time: 13,201
