Xbox One Stereo Headset Microphone Replacement
    1. Xbox One Stereo Headset Microphone Replacement, Microphone: step 1, image 1 of 3 Xbox One Stereo Headset Microphone Replacement, Microphone: step 1, image 2 of 3 Xbox One Stereo Headset Microphone Replacement, Microphone: step 1, image 3 of 3
      • Use the flat end of a spudger to pry out the rubber stopper at the base of the boom.
      Ask FixBot
    2. Xbox One Stereo Headset Microphone Replacement: step 2, image 1 of 1
      • Remove the single 6 mm flathead #2.0 screw exposed after removing the rubber stopper.
      Ask FixBot
    3. Xbox One Stereo Headset Microphone Replacement: step 3, image 1 of 1
      • Lift the joint of the boom up and over its pivot point to separate the microphone from the headset.
      Ask FixBot
    4. Xbox One Stereo Headset Microphone Replacement: step 4, image 1 of 3 Xbox One Stereo Headset Microphone Replacement: step 4, image 2 of 3 Xbox One Stereo Headset Microphone Replacement: step 4, image 3 of 3
      • Using the flat end of the metal spudger, pry the back plate off the boom.
      • The back plate is glued to the boom and must be removed gently.
      • When re-installing, apply a few drops of super glue to hold it in place.
      Ask FixBot
    5. Xbox One Stereo Headset Microphone Replacement: step 5, image 1 of 1
      • Pull the back plate off the boom.
      Ask FixBot
    6. Xbox One Stereo Headset Microphone Replacement: step 6, image 1 of 1
      • Using the flat end of the plastic spudger, gently pry the microphone out of its casing.
      • Desolder the two wires from the back of the microphone. For instructions on how to solder and desolder, please see the soldering technique guide.
      • The white wire connects to the positive node, which is indicated with a "+" on the microphone.
      Ask FixBot
4 other people completed this guide.
Trevor Steele
233 Reputation
1 Guide authored
Cal Poly, Team 17-37, Amido Winter 2015 Member of Cal Poly, Team 17-37, Amido Winter 2015
CPSU-AMIDO-W15S17G37
4 Members
60 Guides authored
9 Guide Comments
Is a replacement microphone available from iFixit?
Scott Minton - Reply Share
What do you replace the mic with?
Its Me - Reply Share
They have the microphone for sale
daniel david guerrerogarcia - Reply Share
Would it presumably be just as easy to replace the microphone speaker with one from another headset, granted it fits ?
harumscxarum - Reply Share
Any mod to make the cable removable?
kikis.andcream - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 46
All Time: 24,966
