Up to 20% off select tools
Xbox One S Power Block Replacement
Views: 93K
View statistics:
Past 24 Hours:
45
Past 7 Days:
224
Past 30 Days:
833
All Time:
93,017
Comments: 68
44 comments on steps, 24 guide comments.
Go to guide comments
Completed: 52
52 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
The power block's connector to the motherboard is difficult to disconnect by hand initially. While unnecessary, we highly recommend removing the motherboard from the silver casing first to access the power block's connector.
    1. Xbox One S Power Block Replacement, Case: step 1, image 1 of 1
      • Flip the Xbox One S so that the bottom of the case is facing upward.
      Ask FixBot
    2. Xbox One S Power Block Replacement: step 2, image 1 of 1
      • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
      • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
      • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
      • It's possible that the clips may break when you remove the bottom from the case.
      • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
      Ask FixBot
    3. Xbox One S Power Block Replacement: step 3, image 1 of 1
      • Once all of the clips are opened, remove the bottom part of the case.
      Ask FixBot
    4. Xbox One S Power Block Replacement: step 4, image 1 of 2 Xbox One S Power Block Replacement: step 4, image 2 of 2
      • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
      Ask FixBot
    5. Xbox One S Power Block Replacement: step 5, image 1 of 2 Xbox One S Power Block Replacement: step 5, image 2 of 2
      • Gently separate the interior case from the white exterior case using the appropriate method.
      • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
      Ask FixBot
    1. Xbox One S Power Block Replacement, Hard Drive Assembly: step 6, image 1 of 2 Xbox One S Power Block Replacement, Hard Drive Assembly: step 6, image 2 of 2
      • To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C5, from the backside of the Xbox One S.
      • Some models may require C4 and C5.
      • This will allow the plastic casing surrounding the hard drive to become detached from the rest of the console.
      Ask FixBot
    2. Xbox One S Power Block Replacement: step 7, image 1 of 3 Xbox One S Power Block Replacement: step 7, image 2 of 3 Xbox One S Power Block Replacement: step 7, image 3 of 3
      • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
      Ask FixBot
    1. Xbox One S Power Block Replacement, Optical Drive Assembly: step 8, image 1 of 1
      • To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C4."
      Ask FixBot
    2. Xbox One S Power Block Replacement: step 9, image 1 of 1
      • Pull the disc drive slightly off the motherboard and disconnect the plastic connectors from the motherboard.
      Ask FixBot
    1. Xbox One S Power Block Replacement, Motherboard: step 10, image 1 of 1
      • To replace the motherboard you must remove the three silver 10 mm T-10 Torx screws labelled "C1," "C2," and "C6."
      • Remove the four black 8 mm T-8 Torx screws lablelled "A1," "A2," "A3," and "A4."
      Ask FixBot
    2. Xbox One S Power Block Replacement: step 11, image 1 of 1
      • Locate the rectangular silver clamp on the opposite corner of the power block.
      • Remove the black bracket near the fan.
      Ask FixBot
    3. Xbox One S Power Block Replacement: step 12, image 1 of 1
      Tool used on this step:
      Buy
      • Grab the clamp with the tweezers. Pull the clamp upward, away from the silver casing. Jiggle it back and forth like a tooth if necessary.
      • It's okay to apply a little bit of force here to get the clamp off the silver casing. The metal is bendable and can be bent/clamped back on.
      Ask FixBot
    4. Xbox One S Power Block Replacement, Remove Wifi antenna: step 13, image 1 of 1
      • Remove the four black 8 mm T-9 Torx screws labeled "E1," "E2," "E3," and "E4."
      Ask FixBot
    5. Xbox One S Power Block Replacement, Remove Mediatek board: step 14, image 1 of 1
      • Remove the three black 8 mm T-9 Torx screws labeled "D1," "D2," and "D3" to remove the Mediatek board.
      Ask FixBot
    6. Xbox One S Power Block Replacement: step 15, image 1 of 1
      • Now that the clamp is removed, gently lift the motherboard from its edges out from the metal casing. The motherboard should come out with ease.
      Ask FixBot
    1. Xbox One S Power Block Replacement, Power Block: step 16, image 1 of 1
      • Gently lift the power block off the motherboard
      Ask FixBot
    2. Xbox One S Power Block Replacement: step 17, image 1 of 1
      • Locate the black connector that joins the power block to the motherboard.
      • The protruding rectangular part of the plastic connector, shown by the orange marker, is a locking tab.
      Ask FixBot
    3. Xbox One S Power Block Replacement: step 18, image 1 of 1
      • Grab the connector as shown, pinch the small black locking tab, and pull firmly upward to detach the power block from the motherboard .
      Ask FixBot
52 other people completed this guide.
Author
with
Erik Ramazzini
3,400 Reputation
3 Guides authored
Cal Poly, Team S22-G3, Livingston Spring 2017 Member of Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 Members
132 Guides authored
24 Guide Comments
So my Xbox One S isn’t turning on at all. No light, nothing. I went to take it apart and I plugged it in just to see if it would boot out of the blue. I turned it on and nothing happened but I can hear a faint clicking sound from the power supply. Does that mean, the power supply has gone bad, and I’ll need to replace it?
Cyology.IO - Reply Share
yes because this xbox one s internal power supply is a fail.. look at there newer model the “xbox one x “ the internal powersupply of it has air ventilation coming from the upgraded version of the fan.
meaning the xbox one s power supply has no proper ventilation no air that blow the exhaust the heat will stuck up inside .. thats why it will not last longer .
the worst is that its design it self .. imagine when you accidentaly pour a water into the fan .. the water will go directly to the cpu and mobo.
that is why they upgrade the “xbox one x“ they copied the design from the ps4 that the air ventilation is on the side panels..
Michael Creech - Reply Share
My xbox one s stopped working after a power surge from a string of storms. It wont respond, make any noise at all. I figured i would replace the power supply and see if that’s the fix. While i’m waiting for the part to arrive, i’m wondering if there is any other damage that could’ve been done by the surge. Or does the power supply prevent that?
quintalnick - Reply Share
did you ever get that storm Xbox to work? I just lost mine to a storm last night :(
Adam Portugali - Reply Share
my one s is working fine all apps are good my network connection is goood its cleaned and maintenanced properly all is working well until i try doing the one thing i bought it for playing games doesnt matter if its disc or downloaded soon as it loads and im ready to play the console crashes to no signal and shuts off
spanky8623 - Reply Share
Past 24 Hours: 45
Past 7 Days: 224
Past 30 Days: 833
All Time: 93,017
