Xbox One S IR Blaster and Wireless Controller Replacement
    1. Xbox One S IR Blaster and Wireless Controller Replacement, Case: step 1, image 1 of 1
      • Flip the Xbox One S so that the bottom of the case is facing upward.
      Ask FixBot
    2. Xbox One S IR Blaster and Wireless Controller Replacement: step 2, image 1 of 1
      • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
      • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
      • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
      • It's possible that the clips may break when you remove the bottom from the case.
      • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
      Ask FixBot
    3. Xbox One S IR Blaster and Wireless Controller Replacement: step 3, image 1 of 1
      • Once all of the clips are opened, remove the bottom part of the case.
      Ask FixBot
    4. Xbox One S IR Blaster and Wireless Controller Replacement: step 4, image 1 of 2 Xbox One S IR Blaster and Wireless Controller Replacement: step 4, image 2 of 2
      • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
      Ask FixBot
    5. Xbox One S IR Blaster and Wireless Controller Replacement: step 5, image 1 of 2 Xbox One S IR Blaster and Wireless Controller Replacement: step 5, image 2 of 2
      • Gently separate the interior case from the white exterior case using the appropriate method.
      • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
      Ask FixBot
    1. Xbox One S IR Blaster and Wireless Controller Replacement, IR Blaster and Controller Wireless Connection: step 6, image 1 of 1
      • The IR blaster can be identified on one of the sides of the interior case. It will be next to the disc drive and near the fan.
      Ask FixBot
    2. Xbox One S IR Blaster and Wireless Controller Replacement: step 7, image 1 of 1
      • Use a Torx T8 screwdriver to remove the four 15 mm screws with orange circles around them.
      • Gently pull the IR blaster off the case.
      Ask FixBot
16 other people completed this guide.
Christopher Chen
728 Reputation
2 Guides authored
Cal Poly, Team S22-G3, Livingston Spring 2017 Member of Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 Members
132 Guides authored
2 Guide Comments
When the board gets replaced does the power light still function normally? I just replaced one because a power button failed and while the new switches work the indicator lights will not power on
Brandon Shrader - Reply Share
Question. What's size and type of button does this board use? I have one with the eject and sync button sheered off.
Frank urmom - Reply Share
Past 24 Hours: 7
Past 7 Days: 34
Past 30 Days: 181
All Time: 8,183
