Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓If you want to replace the hard drive with one that has a larger capacity, this guide will teach you how to replace the hard drive.
Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C5, from the backside of the Xbox One S.
20 other people completed this guide.
2 Guide Comments
My F3 isn't coming out. The screwdriver isn't sitting tight like it is for the other ones. Any idea on how to fix that?
Where is the guide to the replacing of hardrive to a HDD 3.5 instead of 2.5, I thought I found it on here but I have not been able to locate it since.
