Xbox One S All Digital Edition Wifi Card Replacement
    1. Xbox One S All Digital Edition Wifi Card Replacement, Plastic Enclosure: step 1, image 1 of 3 Xbox One S All Digital Edition Wifi Card Replacement, Plastic Enclosure: step 1, image 2 of 3 Xbox One S All Digital Edition Wifi Card Replacement, Plastic Enclosure: step 1, image 3 of 3
      • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
      • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
      • Repeat on different points of the plastic enclosure until the bottom cover is removed.
      Ask FixBot
    2. Xbox One S All Digital Edition Wifi Card Replacement: step 2, image 1 of 2 Xbox One S All Digital Edition Wifi Card Replacement: step 2, image 2 of 2
      • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
      • These screws hold the top cover of the plastic enclosure to the chassis.
      Ask FixBot
    3. Xbox One S All Digital Edition Wifi Card Replacement: step 3, image 1 of 2 Xbox One S All Digital Edition Wifi Card Replacement: step 3, image 2 of 2
      • Apply pressure to peel off the sides of the casing.
      • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
      • The plastic back panel is meant to stay attached to the metal chassis.
      Ask FixBot
    4. Xbox One S All Digital Edition Wifi Card Replacement: step 4, image 1 of 1
      • Flip the metal enclosure so that the fan cover is on top.
      Ask FixBot
    1. Xbox One S All Digital Edition Wifi Card Replacement, Wifi Card: step 5, image 1 of 2 Xbox One S All Digital Edition Wifi Card Replacement, Wifi Card: step 5, image 2 of 2
      • Remove the three 15 mm screws with the Torx T8 Security Bit Screwdriver.
      • The top of the metal chassis has been removed in the picture, but is not necessary for the replacement.
      Ask FixBot
    2. Xbox One S All Digital Edition Wifi Card Replacement: step 6, image 1 of 1
      • Carefully remove the WiFi Card from the metal chassis.
      Ask FixBot
2 other people completed this guide.
Jules Hajjar
2,122 Reputation
8 Guides authored
Cal Poly, Team S12-G6, Regan Fall 2019 Member of Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 81
All Time: 2,948
