Xbox One S All Digital Edition Hard Drive Replacement
Views: 17K
View statistics:
Past 24 Hours:
11
Past 7 Days:
77
Past 30 Days:
327
All Time:
17,142
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 19
19 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This replacement guide provides a step by step process on replacing the Hard Drive of the Xbox One S All Digital Edition (Model 1681). The Hard Drive is responsible for storing games or any downloadable content. Symptoms of a broken Hard Drive are if a user is unable to download or access downloaded games or content. Disconnect all cables prior to disassembly.
Parts
  • Xbox One S HDD
    4.8
    View
Tools
    1. Xbox One S All Digital Edition Hard Drive Replacement, Plastic Enclosure: step 1, image 1 of 3 Xbox One S All Digital Edition Hard Drive Replacement, Plastic Enclosure: step 1, image 2 of 3 Xbox One S All Digital Edition Hard Drive Replacement, Plastic Enclosure: step 1, image 3 of 3
      • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
      • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
      • Repeat on different points of the plastic enclosure until the bottom cover is removed.
      Ask FixBot
    2. Xbox One S All Digital Edition Hard Drive Replacement: step 2, image 1 of 2 Xbox One S All Digital Edition Hard Drive Replacement: step 2, image 2 of 2
      • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
      • These screws hold the top cover of the plastic enclosure to the chassis.
      Ask FixBot
    3. Xbox One S All Digital Edition Hard Drive Replacement: step 3, image 1 of 2 Xbox One S All Digital Edition Hard Drive Replacement: step 3, image 2 of 2
      • Apply pressure to peel off the sides of the casing.
      • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
      • The plastic back panel is meant to stay attached to the metal chassis.
      Ask FixBot
    4. Xbox One S All Digital Edition Hard Drive Replacement: step 4, image 1 of 1
      • Flip the metal enclosure so that the fan cover is on top.
      Ask FixBot
    1. Xbox One S All Digital Edition Hard Drive Replacement, Top Metal Shield: step 5, image 1 of 2 Xbox One S All Digital Edition Hard Drive Replacement, Top Metal Shield: step 5, image 2 of 2
      • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
      Ask FixBot
    2. Xbox One S All Digital Edition Hard Drive Replacement: step 6, image 1 of 3 Xbox One S All Digital Edition Hard Drive Replacement: step 6, image 2 of 3 Xbox One S All Digital Edition Hard Drive Replacement: step 6, image 3 of 3
      • Carefully slide the top metal case off the frame.
      • This may require shifting the case side to side as you slide up.
      Ask FixBot
    1. Xbox One S All Digital Edition Hard Drive Replacement, Hard Drive: step 7, image 1 of 2 Xbox One S All Digital Edition Hard Drive Replacement, Hard Drive: step 7, image 2 of 2
      • Remove the two 10mm screws, labeled C3 and C4, attaching the plastic hard drive case to the metal chassis with the Torx T10 Security screwdriver.
      Ask FixBot
    2. Xbox One S All Digital Edition Hard Drive Replacement: step 8, image 1 of 3 Xbox One S All Digital Edition Hard Drive Replacement: step 8, image 2 of 3 Xbox One S All Digital Edition Hard Drive Replacement: step 8, image 3 of 3
      • Lift the hard drive and the black plastic casing from the chassis.
      • Remove the two sets of wires from the motherboard by gently pulling them directly upward.
      Ask FixBot
    3. Xbox One S All Digital Edition Hard Drive Replacement: step 9, image 1 of 2 Xbox One S All Digital Edition Hard Drive Replacement: step 9, image 2 of 2
      • Remove the four 10mm screws attaching the hard drive to the plastic casing with the Torx T8 Security screwdriver.
      Ask FixBot
    4. Xbox One S All Digital Edition Hard Drive Replacement: step 10, image 1 of 1
      • Carefully remove the hard drive from its plastic case.
      Ask FixBot
    5. Xbox One S All Digital Edition Hard Drive Replacement: step 11, image 1 of 2 Xbox One S All Digital Edition Hard Drive Replacement: step 11, image 2 of 2
      • Carefully remove the black wire connection from the hard drive by gently pulling away from the hard drive.
      Ask FixBot
19 other people completed this guide.
Jules Hajjar
2,122 Reputation
8 Guides authored
Cal Poly, Team S12-G6, Regan Fall 2019 Member of Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
4 Members
96 Guides authored
3 Guide Comments
Great guide, did though run into problems when using a SSD under 500GB (Kioxia 480GB), seems that the drive must be 500+GB because it did work with Kioxia 960GB. Use the official link for software reinstallation not the broken links in the guide.
Peter H - Reply Share
Right, how about the hard drive reload?
Alex T - Reply Share
It's in the conclusion section
John Bagby - Reply Share
Past 24 Hours: 11
Past 7 Days: 77
Past 30 Days: 327
All Time: 17,142
