Up to 20% off select tools
Xbox One Optical Drive Replacement
Views: 210K
View statistics:
Past 24 Hours:
33
Past 7 Days:
224
Past 30 Days:
817
All Time:
209,924
Comments: 95
49 comments on steps, 46 guide comments.
Go to guide comments
Completed: 93
93 people have marked this guide "completed." Will you be next?
Favorites: 18
18 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Stuck disk? Having trouble installing that new game, or loading up your Blu-ray copy of Con Air? Follow this guide to replace a broken optical drive in your Xbox One.
Video Overview
    1. Xbox One Optical Drive Replacement, Upper Case: step 1, image 1 of 1
      Ask FixBot
    2. Xbox One Optical Drive Replacement: step 2, image 1 of 2 Xbox One Optical Drive Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to pry up and remove the plastic vent that surrounds the side USB port.
      • The vent is fairly flexible, and held in place with weak plastic clips—start prying from the back and peel it out.
      Ask FixBot
    3. Xbox One Optical Drive Replacement: step 3, image 1 of 2 Xbox One Optical Drive Replacement: step 3, image 2 of 2
      • There is a small plastic tab that reinforces the front corner of the Xbox.
      • Slide the tab straight back and remove it.
      Ask FixBot
    4. Xbox One Optical Drive Replacement: step 4, image 1 of 2 Xbox One Optical Drive Replacement: step 4, image 2 of 2
      • Insert the flat end of a spudger between the upper and lower case where they meet at the rear of the side vent opening.
      • There is a strong plastic clip connecting the two case halves (the first of many), so you'll need to use quite a bit of force.
      • Leave the spudger in place until you open the case completely. The clips are very springy and may cause the case to snap shut while you're working.
      Ask FixBot
    5. Xbox One Optical Drive Replacement: step 5, image 1 of 2 Xbox One Optical Drive Replacement: step 5, image 2 of 2
      • The interface between the upper and lower cases is secured by several clips along the rear and remaining side of the Xbox.
      • Insert a plastic opening tool between the upper and lower case to separate the clip over the rear vent.
      Ask FixBot
    6. Xbox One Optical Drive Replacement: step 6, image 1 of 2 Xbox One Optical Drive Replacement: step 6, image 2 of 2
      • Keep moving along the rear of the Xbox, prying up clips.
      • Make sure the spudger stays in its blocking position—even if the case opens up enough for the spudger to fall out, the remaining clips are springy and may pull the case completely shut. Keep the spudger in the gap to protect your progress.
      Ask FixBot
    7. Xbox One Optical Drive Replacement: step 7, image 1 of 2 Xbox One Optical Drive Replacement: step 7, image 2 of 2
      • Keep popping clips. It may help to slide the plastic opening tool across the clips.
      • By the time you get to the far edge of the rear case, the top case should be ready to come off. If not, run your plastic opening tool around the corner and pop the clips along the side without the USB port.
      Ask FixBot
    8. Xbox One Optical Drive Replacement: step 8, image 1 of 3 Xbox One Optical Drive Replacement: step 8, image 2 of 3 Xbox One Optical Drive Replacement: step 8, image 3 of 3
      • Starting with the spudger you left in the crack, pry the upper case up to free the last few clips.
      • Use a plastic opening tool to pop any straggler clips that weren't freed.
      • Do not try to remove the upper case yet, as it is still connected by the front panel button cable.
      • Lift the upper case slightly and shift it to give access to the front panel board.
      Ask FixBot
    9. Xbox One Optical Drive Replacement: step 9, image 1 of 3 Xbox One Optical Drive Replacement: step 9, image 2 of 3 Xbox One Optical Drive Replacement: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • The front button cable has a unique ZIF connector—pay attention to the next few steps to safely disconnect it.
      • Use tweezers to lift the blue plastic retaining loop over the white connector on the board.
      • Use the tip of a spudger to push the connector's locking tab toward the cable to unlatch it.
      Ask FixBot
    10. Xbox One Optical Drive Replacement: step 10, image 1 of 2 Xbox One Optical Drive Replacement: step 10, image 2 of 2
      • Use tweezers to pull the cable straight out of the connector on the board.
      • Remove the upper case.
      Ask FixBot
    11. Xbox One Optical Drive Replacement, Reassembly Instructions: step 11, image 1 of 3 Xbox One Optical Drive Replacement, Reassembly Instructions: step 11, image 2 of 3 Xbox One Optical Drive Replacement, Reassembly Instructions: step 11, image 3 of 3
      • The next 4 steps are directions for reassembly. Skip them to continue with disassembly.
      • Use the flat end of a spudger to free the clips securing the front panel to the upper case.
      • Remove the front panel from the rest of the upper case.
      Ask FixBot
    12. Xbox One Optical Drive Replacement: step 12, image 1 of 3 Xbox One Optical Drive Replacement: step 12, image 2 of 3 Xbox One Optical Drive Replacement: step 12, image 3 of 3
      • Replace the top part of the upper case.
      • Line up the clips and press firmly to re-seat them around the perimeter.
      Ask FixBot
    13. Xbox One Optical Drive Replacement: step 13, image 1 of 3 Xbox One Optical Drive Replacement: step 13, image 2 of 3 Xbox One Optical Drive Replacement: step 13, image 3 of 3
      • Support the front panel near the front of the Xbox.
      • Use tweezers to replace the front button cable in its ZIF socket.
      • Use the flat end of a spudger to push the ZIF lock to the left to secure the cable.
      Ask FixBot
    14. Xbox One Optical Drive Replacement: step 14, image 1 of 3 Xbox One Optical Drive Replacement: step 14, image 2 of 3 Xbox One Optical Drive Replacement: step 14, image 3 of 3
      • The lower edge of the front panel has plastic hooks that interlock with plastic hooks on the front edge of the lower case.
      • With the front panel at a 45 degree angle, interlock its plastic hooks with those in the lower case.
      • Push the top of the front panel into the Xbox, like closing a mailbox. Press firmly so that the clips securing the front panel to the upper case lock securely.
      Ask FixBot
    1. Xbox One Optical Drive Replacement, Upper Metal Case: step 15, image 1 of 3 Xbox One Optical Drive Replacement, Upper Metal Case: step 15, image 2 of 3 Xbox One Optical Drive Replacement, Upper Metal Case: step 15, image 3 of 3
      • Gently pull up on the speaker cable connector to disconnect it from the front panel board.
      • Be careful to pull up on the cable's connector and not the connector on the board. It's pretty flimsy and you might accidentally pull it off the board entirely.
      • Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
      Ask FixBot
    2. Xbox One Optical Drive Replacement: step 16, image 1 of 3 Xbox One Optical Drive Replacement: step 16, image 2 of 3 Xbox One Optical Drive Replacement: step 16, image 3 of 3
      • Remove the two 9.5 mm T8 Torx screws from the WI-Fi board.
      • Lift the Wi-Fi board straight up from its socket in the upper metal case.
      • Leaving the Wi-Fi board antenna cable in place, move the Wi-Fi board aside, exposing the screw labeled "C3" that was beneath it.
      Ask FixBot
    3. Xbox One Optical Drive Replacement: step 17, image 1 of 1
      • Remove the eight 65 mm Torx T10 screws from the top of the upper metal case.
      Ask FixBot
    4. Xbox One Optical Drive Replacement: step 18, image 1 of 2 Xbox One Optical Drive Replacement: step 18, image 2 of 2
      • Lift—but do not remove—the upper metal case.
      • The Wi-Fi board interconnect cable connects the upper metal case to the motherboard.
      Ask FixBot
    5. Xbox One Optical Drive Replacement: step 19, image 1 of 2 Xbox One Optical Drive Replacement: step 19, image 2 of 2
      • Disconnect the Wi-Fi board interconnect cable from the motherboard.
      • Remove the upper metal case.
      Ask FixBot
    1. Xbox One Optical Drive Replacement, Optical Drive: step 20, image 1 of 2 Xbox One Optical Drive Replacement, Optical Drive: step 20, image 2 of 2
      • Disconnect the optical drive power and SATA data cables from the motherboard.
      Ask FixBot
    2. Xbox One Optical Drive Replacement: step 21, image 1 of 1
      • Remove the optical drive assembly from the Xbox.
      Ask FixBot
    3. Xbox One Optical Drive Replacement: step 22, image 1 of 3 Xbox One Optical Drive Replacement: step 22, image 2 of 3 Xbox One Optical Drive Replacement: step 22, image 3 of 3
      • The optical drive tray is held onto the optical drive by two plastic clips.
      • Push the clips outward and then slide the tray off the drive.
      Ask FixBot
    4. Xbox One Optical Drive Replacement: step 23, image 1 of 2 Xbox One Optical Drive Replacement: step 23, image 2 of 2
      • Remove the optical drive power and SATA data cables.
      Ask FixBot
93 other people completed this guide.
Author
with
Andrew Optimus Goldheart
516,610 Reputation
405 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
46 Guide Comments
I torn down my one to attempt to see why it stopped reading disc, i discovered that it wasn't a spinning issue but that the disc popped back out just a bit leading to why it will not spin. Any way of fixing that?
Ryan Ninteau - Reply Share
there is a black bar that rolls the disc into the tray try cleaning that (you will have to fully open the disc drive)
codycggrimm - Reply Share
What kind of optical drive should I use?
DZ - Reply Share
Once replacing the optical drive does one need to flashit/swap pcb boards. Has Microsoft stopped hard coding these.
Rick Mizell - Reply Share
I would like to know the answer to this as well. My xbox has a terrible time loading discs. If I use the hold method to install the disc it will eventually read it.
shaunwiegert - Reply Share
Past 24 Hours: 33
Past 7 Days: 224
Past 30 Days: 817
All Time: 209,924
