Up to 20% off select tools
Xbox One Optical Drive Laser Replacement
Views: 12K
View statistics:
Past 24 Hours:
12
Past 7 Days:
88
Past 30 Days:
383
All Time:
11,600
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
This guide explains how to replace the Xbox One's optical drive laser. Replacing the optical drive laser serves as a simpler solution for problems with the optical drive without the need to replace the console’s paired motherboard and optical drive daughterboard.
    1. Xbox One Optical Drive Laser Replacement, Optical Drive Case Screws: step 1, image 1 of 1
      • Make sure the optical drive is not connected to any power source and is powered off.
      • Unscrew the four Phillips #1 screws on the top of the optical drive.
      Ask FixBot
    2. Xbox One Optical Drive Laser Replacement, Optical Drive Case Lid: step 2, image 1 of 1
      • Lift the lid off of the optical drive case, this should require little to no force.
      Ask FixBot
    3. Xbox One Optical Drive Laser Replacement, Optical Drive Case: step 3, image 1 of 2 Xbox One Optical Drive Laser Replacement, Optical Drive Case: step 3, image 2 of 2
      • Slide the remaining optical drive case off of the internal components.
      • Internal components often snag on these points when removing the optical drive case.
      Ask FixBot
    4. Xbox One Optical Drive Laser Replacement, ZIF Connectors: step 4, image 1 of 2 Xbox One Optical Drive Laser Replacement, ZIF Connectors: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Locate the three ZIF connectors on the optical drive PCB.
      • Using tweezers, gently lift the tab on each ZIF connector to release the ribbon cables.
      • Remove the ribbon cable from each ZIF connector.
      Ask FixBot
    5. Xbox One Optical Drive Laser Replacement, PCB Screws: step 5, image 1 of 1
      • Unscrew the three Phillips #0 screws mounting the PCB.
      Ask FixBot
    6. Xbox One Optical Drive Laser Replacement, Moving the PCB: step 6, image 1 of 1
      • Gently lift the PCB and place it to the side.
      • When lifting the PCB, be careful to not detach the wires connecting the PCB to the motor.
      Ask FixBot
    7. Xbox One Optical Drive Laser Replacement, Optical Drive Laser Screws: step 7, image 1 of 1
      • Unscrew the three Phillips #0 screws mounting the optical drive laser.
      Ask FixBot
    8. Xbox One Optical Drive Laser Replacement, Optical Drive Laser: step 8, image 1 of 1
      • Lift the old optical drive laser from the unit and place in the new optical drive laser.
      Ask FixBot
10 other people completed this guide.
Author
with
Austin Stein
399 Reputation
1 Guide authored
2 Guide Comments
If my xbox one is reading Bluray disc(xbox one games/ Bluray movies), but for DVD it work sometimes, sometimes it wont (xbox 360 games/ DVD), should i replace the whole bluray drive or this Optical drive laser?
Ali Kazimi - Reply Share
I would start with this repair. A faulty laser sounds like a very likely source for your issue. If it doesn't work you have a problem with the drive board.
Replacing the entire drive would require you to replace the main motherboard of the Xbox with one from the same console that the replacement drive came from because they are linked as an anti-piracy measure. At that point you're better off replacing the entire console.
Austin Stein - Reply Share
Past 24 Hours: 12
Past 7 Days: 88
Past 30 Days: 383
All Time: 11,600
