Up to 20% off select tools
Xbox One Kinect LED Sensor Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
106
All Time:
1,940
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The LED sensor lights up when the sensor is connected. If the LED is unlit, the sensor module itself may be at fault.
    1. Xbox One Kinect LED Sensor Replacement, Outer Shell: step 1, image 1 of 1
      • Remove the sticker on the underside of the device.
      • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
      • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
      Ask FixBot
    2. Xbox One Kinect LED Sensor Replacement: step 2, image 1 of 3 Xbox One Kinect LED Sensor Replacement: step 2, image 2 of 3 Xbox One Kinect LED Sensor Replacement: step 2, image 3 of 3
      • Remove the back panel.
      • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
      Ask FixBot
    3. Xbox One Kinect LED Sensor Replacement: step 3, image 1 of 3 Xbox One Kinect LED Sensor Replacement: step 3, image 2 of 3 Xbox One Kinect LED Sensor Replacement: step 3, image 3 of 3
      • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
      • Lift the internal assembly with the spudger.
      • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
      Ask FixBot
    1. Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: step 4, image 1 of 3 Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: step 4, image 2 of 3 Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: step 4, image 3 of 3
      • Disconnect the ribbon cable between the sensor driver board and the motherboard.
      • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
      • Remove the infrared sensor board for the Kinect.
      Ask FixBot
Author
with
Malak Anshassi
356 Reputation
3 Guides authored
USF Tampa, Team 1-3, Hickman Fall 2014 Member of USF Tampa, Team 1-3, Hickman Fall 2014
USFT-HICKMAN-F14S1G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 106
All Time: 1,940
