Up to 20% off select tools
Xbox One Kinect Infrared Blasters Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
95
All Time:
3,098
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
Infrared blasters emulate an IR signal. This is used to remote-control other equipment in the vicinity of the Kinect. The IR blasters are mounted on the heat sink inside the Kinect.
    1. Xbox One Kinect Infrared Blasters Replacement, Outer Shell: step 1, image 1 of 1
      • Remove the sticker on the underside of the device.
      • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
      • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
      Ask FixBot
    2. Xbox One Kinect Infrared Blasters Replacement: step 2, image 1 of 3 Xbox One Kinect Infrared Blasters Replacement: step 2, image 2 of 3 Xbox One Kinect Infrared Blasters Replacement: step 2, image 3 of 3
      • Remove the back panel.
      • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
      Ask FixBot
    3. Xbox One Kinect Infrared Blasters Replacement: step 3, image 1 of 3 Xbox One Kinect Infrared Blasters Replacement: step 3, image 2 of 3 Xbox One Kinect Infrared Blasters Replacement: step 3, image 3 of 3
      • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
      • Lift the internal assembly with the spudger.
      • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
      Ask FixBot
    1. Xbox One Kinect Infrared Blasters Replacement, Heat Sink Assembly: step 4, image 1 of 2 Xbox One Kinect Infrared Blasters Replacement, Heat Sink Assembly: step 4, image 2 of 2
      • Remove the eight 2.9x7.6 mm T9 screws from the rear of the internal case.
      • Lift the internal metal case from the plastic shell enclosing the heat sink assembly.
      Ask FixBot
    2. Xbox One Kinect Infrared Blasters Replacement: step 5, image 1 of 3 Xbox One Kinect Infrared Blasters Replacement: step 5, image 2 of 3 Xbox One Kinect Infrared Blasters Replacement: step 5, image 3 of 3
      • Disconnect the ribbon cable between the sensor driver board and the motherboard.
      • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
      • Remove the infrared sensor board for the Kinect.
      Ask FixBot
    3. Xbox One Kinect Infrared Blasters Replacement: step 6, image 1 of 3 Xbox One Kinect Infrared Blasters Replacement: step 6, image 2 of 3 Xbox One Kinect Infrared Blasters Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Detach the ribbon cable leading to the microphone with the tweezers.
      • Remove the four 3.1x7.7 mm T9 screws connecting the microphone to the heat sink assembly.
      • Remove the stand.
      Ask FixBot
    4. Xbox One Kinect Infrared Blasters Replacement: step 7, image 1 of 3 Xbox One Kinect Infrared Blasters Replacement: step 7, image 2 of 3 Xbox One Kinect Infrared Blasters Replacement: step 7, image 3 of 3
      • Remove the eight 3.0x7.6 mm T9 screws from the motherboard.
      • Peel away the plastic film from the motherboard using the spudger.
      • Detach the ribbon cable leading to the color camera using the spudger.
      Ask FixBot
    5. Xbox One Kinect Infrared Blasters Replacement: step 8, image 1 of 3 Xbox One Kinect Infrared Blasters Replacement: step 8, image 2 of 3 Xbox One Kinect Infrared Blasters Replacement: step 8, image 3 of 3
      • Lift the motherboard and the heat sink assembly from the plastic shell. The components attached to the heat sink are now accessible.
      Ask FixBot
    1. Xbox One Kinect Infrared Blasters Replacement, Infrared Blasters: step 9, image 1 of 3 Xbox One Kinect Infrared Blasters Replacement, Infrared Blasters: step 9, image 2 of 3 Xbox One Kinect Infrared Blasters Replacement, Infrared Blasters: step 9, image 3 of 3
      • Using a T5 torx driver, remove the four 1.9x10 mm screws on the corners of the blasters.
      • Remove the two 1.9x5.1 mm T5 screws on the right-hand side of the board.
      Ask FixBot
    2. Xbox One Kinect Infrared Blasters Replacement: step 10, image 1 of 2 Xbox One Kinect Infrared Blasters Replacement: step 10, image 2 of 2
      • Using the spudger, detach the IR blaster board from the heatsink.
      Ask FixBot
    3. Xbox One Kinect Infrared Blasters Replacement: step 11, image 1 of 3 Xbox One Kinect Infrared Blasters Replacement: step 11, image 2 of 3 Xbox One Kinect Infrared Blasters Replacement: step 11, image 3 of 3
      • Remove the four 1.9x5.1 mm T5 screws from the back of the board.
      • Gently remove the IR blasters from the board.
      • Obtain replacement blasters.
      Ask FixBot
Author
with
Jonathan Samuelson
176 Reputation
1 Guide authored
USF Tampa, Team 1-3, Hickman Fall 2014 Member of USF Tampa, Team 1-3, Hickman Fall 2014
USFT-HICKMAN-F14S1G3
4 Members
84 Guides authored
1 Guide Comment
please where to buy those IR blasters ???
Michel Melek - Reply Share
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 95
All Time: 3,098
