Video Instructions
To reassemble your device, follow these instructions:
4 other people completed this guide.
Past 24 Hours: 21
Past 7 Days: 131
Past 30 Days: 455
All Time: 13,064
5 Guide Comments
Less than 6 months of having this and the RB has to apply more pressure to work. To fix this I have to solder. I won't buy this controller ever again.
PrivateUser30 - Reply Share
Me too. It's hard to believe, but it's true: the Elite 2 controller costs many times more than a regular one. However, its quality doesn't justify the price at all. In short: the price is much higher, and the quality is much lower. Shame on you, Microsoft..."
NordKeta - Reply Share
I keep having issues, I manage to remove the button but there is still solder stuck in the hole so I cannot passthrough a new button... I have used wick, solder pump and reflowing with new solder, nothing works?
Any ideas??
Craig Ireland - Reply Share
You could try adding more solder and keep it liquid while someone slides the button in from the other side... Not the best idea, but if you're short on options and if it's only one hole having this problem it might work.
Iris - Reply Share
Hey, use desoldering pump to clean pins. Don’t overheat plate.
Dmytro Mak - Reply Share
