Xbox One Elite Controller (Model 1698) Rumble Motor Replacement
Views: 13K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
137
All Time:
12,894
Comments: 11
11 comments on steps.
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Difficult
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If your Xbox One Elite Controller is not vibrating, your rumble motors might be disconnected or defective. Here are instructions to help you replace your rumble motors. Use the Soldering Iron Guide to attach the wires of the new rumble motor to the motherboard.
Parts
Tools
    1. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement, Battery: step 1, image 1 of 1
      • Turn over the controller so that the buttons face down.
      • Be gentle when removing the cover so you do not break the small plastic tabs holding the cover to the controller.
      • Remove the battery cover carefully by sliding the cover up in the direction of the arrow.
      Ask FixBot
    2. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: step 2, image 1 of 2 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: step 2, image 2 of 2
      • Remove the two batteries AA batteries by lifting them from one end and pulling them out.
      Ask FixBot
    1. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement, Rumble Motor: step 3, image 1 of 3 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement, Rumble Motor: step 3, image 2 of 3 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement, Rumble Motor: step 3, image 3 of 3
      • Be careful not to break the plastic tabs, that hold each grip cover to the back of the controller.
      • Remove each grip by inserting the plastic opening tool near the top of the controller.
      • Guide the plastic opening tool along the entire seam and gently separate the grip from the controller in a prying motion as you go.
      Ask FixBot
    2. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: step 4, image 1 of 2 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: step 4, image 2 of 2
      • Remove the five 2.3 mm screws with the TR8 Torx Security screwdriver.
      • Four of the screws are located at the bottom tip of each grip and at the top of each grip, near the triggers of the controller.
      • The last screw is located in the center of the battery tray beneath a sticker.
      • Use a TR8 Torx Security Screwdriver to puncture the sticker and remove the final screw.
      Ask FixBot
    3. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: step 5, image 1 of 3 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: step 5, image 2 of 3 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: step 5, image 3 of 3
      • Flip the controller so that the buttons are face up to prevent the vibration motors from falling out of the controller.
      • Remove the D-pad by lifting the bottom and pulling it up.
      • Remove the entire plastic faceplate by pulling it up gently.
      • Remove the thumbsticks by pulling them off from the top.
      Ask FixBot
    4. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: step 6, image 1 of 2 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: step 6, image 2 of 2
      • Remove the small black mode switch from the front of the controller.
      • The backplate gets a little stuck on the port at the bottom so you may have to use a prying motion to remove.
      • Be careful in the next step when pulling the main assembly apart from the backplate. There is a ribbon cable that connects the two parts that must stay in tact.
      • Remove the backplate from the main assembly by pulling them apart.
      Ask FixBot
    5. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • The small ribbon cable connects the back cover to the internals of the controller. To remove the cable, lift the black lever on the opposite side of the connector from the cable.
      • Use tweezers to unplug the ribbon cable on the side closest to the back cover by pulling the cable parallel to the surface of the circuit board.
      Ask FixBot
    6. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: step 8, image 1 of 2 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: step 8, image 2 of 2
      • Mark each motor according to where it attaches. The rumble motors are different so they will not work if you switch them.
      • Take note of where the red and black motor wires attach because they should be reattached in the same order.
      • Turn over the controller so that the thumbsticks are facing down.
      • Use tweezers and a soldering iron (Soldering Iron Guide) to remove the black and red wires from the motherboard.
      • This will release the rumble motor from the controller assembly.
      Ask FixBot
10 other people completed this guide.
Cara
1,660 Reputation
6 Guides authored
Cal Poly, Team S18-G4, Forte Fall 2017 Member of Cal Poly, Team S18-G4, Forte Fall 2017
CPSU-FORTE-F17S18G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 137
All Time: 12,894
