Xbox One Elite Controller (Model 1698) Daughterboard Replacement
    1. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Show me the Screws!: step 1, image 1 of 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Show me the Screws!: step 1, image 2 of 2
      • You can remove the side panels with a pry tool.
      • You don't need to remove the rubber. The rubber on this controller was already bad.
      Ask FixBot
    2. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Removing the back panel screws: step 2, image 1 of 1
      • Remove the 5 Torx Security Bit (TR9) screws.
      Ask FixBot
    3. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: step 3, image 1 of 3 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: step 3, image 2 of 3 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: step 3, image 3 of 3
      • Pry the panel next to the 3.5mm port.
      • Be careful to not rip the ribbon shown in the next step.
      Ask FixBot
    4. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Warning Carefully remove the ribbon: step 4, image 1 of 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Warning Carefully remove the ribbon: step 4, image 2 of 2
      • Be careful to not rip the ribbon cable.
      • You can pop the connector up to remove the ribbon easily.
      • Ribbon Cable
      Ask FixBot
    5. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Screws on controller motherboard: step 5, image 1 of 1
      • Remove the 2 Torx (T6) screws.
      Ask FixBot
    6. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Desolder wires from motherboard: step 6, image 1 of 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Desolder wires from motherboard: step 6, image 2 of 2
      • Desolder the 4 wires on each side, these control the vibrations and the RT LT.
      Ask FixBot
    7. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the motherboard: step 7, image 1 of 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the motherboard: step 7, image 2 of 2
      • Pull up from the "top" side of the controller on the daughterboard.
      Ask FixBot
    1. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: step 8, image 1 of 3 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: step 8, image 2 of 3 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: step 8, image 3 of 3
      • Be Careful to not lose the sync button.
      • Pry the middle section up from the home button side.
      • This will also remove the LB and RB which is a single part.
      Ask FixBot
    2. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the controller daughterboard: step 9, image 1 of 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the controller daughterboard: step 9, image 2 of 2
      • Unscrew the 6 Torx (T6) screws.
      Ask FixBot
3 other people completed this guide.
EasyAsABC123
2,557 Reputation
5 Guides authored
1 Guide Comment
Hola que tal amigo disculpa es posible sustituir esa misma placa por una de un mando one ?
tay redd - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 79
All Time: 10,785
