Up to 20% off select tools
Xbox Intec 7.2" Color Game Screen Disassembly
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
102
All Time:
1,947
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide will assist you disassemble your Intec 7.2" Color Game Screen attachment. Instructions may be similar to the Intec 5.4" Color Game Screen attachment although this is currently unknown.
    1. Xbox Intec 7.2" Color Game Screen Disassembly, Intec 7.2" Color Game Screen: step 1, image 1 of 2 Xbox Intec 7.2" Color Game Screen Disassembly, Intec 7.2" Color Game Screen: step 1, image 2 of 2
      • Top shell is held in place with 4 screws and 6 retaining tabs
      • Remove 2 rubber pads to uncover 2 hidden screws
      • Remove 4 #1 screws
      Ask FixBot
    2. Xbox Intec 7.2" Color Game Screen Disassembly: step 2, image 1 of 2 Xbox Intec 7.2" Color Game Screen Disassembly: step 2, image 2 of 2
      • Take a spudger and disengage the 6 retaining tabs
      • This will be the most time-consuming step. Be patient and take your time.
      • You will hear an audible pop when disengaging the tabs.
      • Remove top housing
      Ask FixBot
    3. Xbox Intec 7.2" Color Game Screen Disassembly: step 3, image 1 of 2 Xbox Intec 7.2" Color Game Screen Disassembly: step 3, image 2 of 2
      • Remove 2 #1 screws
      • Disconnect 4 wire harnesses
      Ask FixBot
    4. Xbox Intec 7.2" Color Game Screen Disassembly: step 4, image 1 of 3 Xbox Intec 7.2" Color Game Screen Disassembly: step 4, image 2 of 3 Xbox Intec 7.2" Color Game Screen Disassembly: step 4, image 3 of 3
      • Disconnect speaker header
      • It's not necessary to remove the speakers from the housing unless you need to.
      • Disconnect header if speakers need to be removed. Otherwise, this will be done in the next step.
      • Remove 8 #1 screws
      Ask FixBot
    5. Xbox Intec 7.2" Color Game Screen Disassembly: step 5, image 1 of 2 Xbox Intec 7.2" Color Game Screen Disassembly: step 5, image 2 of 2
      • Disconnect 2 headers
      • Lift wires over retaining posts
      Ask FixBot
    6. Xbox Intec 7.2" Color Game Screen Disassembly: step 6, image 1 of 2 Xbox Intec 7.2" Color Game Screen Disassembly: step 6, image 2 of 2
      • Grab the edges of the board and lift up
      • Don't attempt to fully remove the board from the unit yet
      • Disconnect last header
      Ask FixBot
    7. Xbox Intec 7.2" Color Game Screen Disassembly: step 7, image 1 of 1
      • It's not necessary to remove the screen from the housing unless you need to.
      • Remove 4 #1 screws to remove screen
      Ask FixBot
    8. Xbox Intec 7.2" Color Game Screen Disassembly: step 8, image 1 of 2 Xbox Intec 7.2" Color Game Screen Disassembly: step 8, image 2 of 2
      • Lift up on tab
      • Remove 3 #1 screws
      • Grab the edges and lift the board up
      Ask FixBot
    9. Xbox Intec 7.2" Color Game Screen Disassembly: step 9, image 1 of 1
      • Feed wires through the hinge enough to remove board from unit
      • These 4 headers are soldered directly to the board
      • If this board needs to be entirely removed, feed the wires all the way through the hinge.
      Ask FixBot
Author
with
Navy Vet 2015
8,435 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 102
All Time: 1,947
