Up to 20% off select tools
Xbox Hard Drive Replacement
Views: 82K
View statistics:
Past 24 Hours:
16
Past 7 Days:
132
Past 30 Days:
553
All Time:
81,560
Comments: 30
9 comments on steps, 21 guide comments.
Go to guide comments
Completed: 70
70 people have marked this guide "completed." Will you be next?
Favorites: 64
64 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace your Xbox's hard drive.
    1. Xbox Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
      • Make sure your Xbox is safely unplugged and is laying on a flat, stable surface.
      Ask FixBot
    2. Xbox Hard Drive Replacement: step 2, image 1 of 1
      • Turn the Xbox over to reveal the four rubber feet.
      • Use a metal spudger to pry off the four rubber feet.
      Ask FixBot
    3. Xbox Hard Drive Replacement: step 3, image 1 of 2 Xbox Hard Drive Replacement: step 3, image 2 of 2
      • There are 2 more screws hidden under the two labels on the bottom of the case.
      • You can either remove the labels or simply feel for the screw holes through the labels and then cut or punch a hole through them.
      Ask FixBot
    4. Xbox Hard Drive Replacement: step 4, image 1 of 1
      • Remove the six T20 Torx screws securing the top cover to the bottom cover.
      Ask FixBot
    5. Xbox Hard Drive Replacement: step 5, image 1 of 2 Xbox Hard Drive Replacement: step 5, image 2 of 2
      • Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover.
      Ask FixBot
    6. Xbox Hard Drive Replacement: step 6, image 1 of 2 Xbox Hard Drive Replacement: step 6, image 2 of 2
      • Remove the three 3 mm T10 screws securing the hard drive to the Xbox.
      • There is one screw on the rear left side of the hard drive that is only visible when the IDE ribbon cable is lifted up. The other two are at the front right and left sides of the hard drive.
      • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
      • Only the screw under the ribbon cable is for the hard drive, while the other two are for the disk drive. But it's easiest to remove all three during this step, as they are the same T10 screws.
      Ask FixBot
    7. Xbox Hard Drive Replacement: step 7, image 1 of 2 Xbox Hard Drive Replacement: step 7, image 2 of 2
      • Free the hard drive power cable from the carrier for sufficient slack to lift the hard drive out.
      • Lift the plastic hard drive carrier out of the Xbox case.
      Ask FixBot
    8. Xbox Hard Drive Replacement: step 8, image 1 of 3 Xbox Hard Drive Replacement: step 8, image 2 of 3 Xbox Hard Drive Replacement: step 8, image 3 of 3
      • Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side).
      • Carefully remove the hard drive from the plastic carrier. Gentle rocking will see the hard drive come out quite easily.
      Ask FixBot
    9. Xbox Hard Drive Replacement: step 9, image 1 of 2 Xbox Hard Drive Replacement: step 9, image 2 of 2
      • Pull both the hard drive data ribbon cable and the power cable straight up from the hard drive.
      • They may be firmly seated, so be careful trying to remove them. DO NOT pull the wires as you may damage the cable assembly.
      Ask FixBot
70 other people completed this guide.
Author
with
rmarstel
6,378 Reputation
5 Guides authored
Cal Poly, Team 18-2, Maness Fall 2009 Member of Cal Poly, Team 18-2, Maness Fall 2009
CPSU-MANESS-F09S18G2
3 Members
60 Guides authored
21 Guide Comments
can you replace the hard drive with one that has windows or linux on it and run windows or linux from the hdd and turn the xbox into a media pc or is the xbox OS not in the hdd but in a chip on the motherboard that cannot be overridden so that it boots from the hdd
Alex Matthiessen - Reply Share
NO, you cannot.
kaos_engr - Reply Share
kaos_engr is wrong. You CAN run Linux on a modded Xbox. Although since you also asked about REPLACING the hard drive: I don’t know whether you have to use the original hard drive or can use any IDE hard drive. But Linux is apparently possible on a modded Xbox. See here, and there are more resources on the web too, just search the web for “original Xbox linux”: https://en.wikipedia.org/wiki/Xbox_Linux
As for Windows on an original Xbox. I’m sure I read once that proper drivers wouldn’t exist. Because nobody would have written them. Certainly Microsoft didn’t want you putting Windows on your Xbox. However I just came across this video of someone allegedly running Windows 98 on an Xbox. I’m not sure if they’re somehow virtualising Windows using Linux or something. Maybe have a look and figure out what’s going on: https://www.youtube.com/watch?v=erk_XE-D...
But Linux on an Xbox does look possible, IF you have a modded Xbox.
D C - Reply Share
http://www.ebay.com/gds/How-To-Determine...
Utilize the information on this website to determine what Xbox version you have so you know what replacement parts to look for.
Navy Vet 2015 - Reply Share
The repairability score varies on the model...
Stephen Kymn - Reply Share
Past 24 Hours: 16
Past 7 Days: 132
Past 30 Days: 553
All Time: 81,560
