Up to 20% off select tools
Xbox Fan Replacement
Views: 10K
View statistics:
Past 24 Hours:
12
Past 7 Days:
47
Past 30 Days:
214
All Time:
10,399
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
This guide can be used to fix the first generation of Xbox. When taking the Xbox apart to replace the fan make sure to be careful in carefully following all of the steps to ensure that you can put it back together properly.
Video Overview
    1. Xbox Fan Replacement, Fan Replacement: step 1, image 1 of 1
      • Turn the Xbox on its back and remove the rubber feet in each corner using a flathead screwdriver.
      Ask FixBot
    2. Xbox Fan Replacement: step 2, image 1 of 1
      • Peel off the stickers on the bottom side of the Xbox and unscrew all six screws using a Torx 20 screwdriver bit. Set the screws off to the side so you don't misplace them.
      Ask FixBot
    3. Xbox Fan Replacement: step 3, image 1 of 1
      • Turn the console upright and remove the lid.
      • If you are having some trouble getting the lid off, try gently shaking the device while you pull up.
      Ask FixBot
    4. Xbox Fan Replacement: step 4, image 1 of 1
      • In order to remove the IDE cable, pull firmly on the cable straight back from the hard drive.
      • This may be slightly difficult; wiggling the cable back and forth will help to unfasten it.
      Ask FixBot
    5. Xbox Fan Replacement: step 5, image 1 of 1
      • Remove the screw from underneath the IDE cable using a Torx 10 screwdriver.
      • This screw is located between the hard drive and DVD drive.
      Ask FixBot
    6. Xbox Fan Replacement: step 6, image 1 of 1
      • Remove the hard drive by pulling it directly up and out of the case.
      • The hard drive is attached to a power cable, but you shouldn't need to remove the power cable to get the drive out unless you are replacing the hard drive.
      Ask FixBot
    7. Xbox Fan Replacement: step 7, image 1 of 1
      • Remove the cable the same way that the hard drive cable was removed. Simply pull the cable straight out from the DVD drive.
      Ask FixBot
    8. Xbox Fan Replacement: step 8, image 1 of 2 Xbox Fan Replacement: step 8, image 2 of 2
      • Remove the screws from each end of the DVD drive using a Torx 10 screwdriver.
      Ask FixBot
    9. Xbox Fan Replacement: step 9, image 1 of 1
      • Once both screws have been removed pull straight upwards to remove the drive.
      Ask FixBot
    10. Xbox Fan Replacement: step 10, image 1 of 1
      • Unscrew all eleven screws that hold the mother board in place. Use a Torx 10 screwdriver to unscrew them.
      Ask FixBot
    11. Xbox Fan Replacement: step 11, image 1 of 1
      • Remove the power cord by gently lifting it out at a 45 degree angle.
      • After the power cord is removed gently lift out the mother board by placing your fingers around the edges inside the case and lifting straight up and out.
      Ask FixBot
    12. Xbox Fan Replacement: step 12, image 1 of 1
      • Remove the old fan by pressing gently on the clips on each side with a flathead screwdriver and then carefully clip in a new fan.
      Ask FixBot
4 other people completed this guide.
Author
with
Keiko McMaster
247 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 47
Past 30 Days: 214
All Time: 10,399
