Up to 20% off select tools
Xbox Duke Controller Potentiometer Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
27
Past 30 Days:
132
All Time:
1,289
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the control sticks on your Xbox Duke Controller aren't registering input or are registering input when you aren't touching them, use this guide to replace them.
Before using this guide, check to see if there is any dirt or debris clogging the space between the controller and the control stick. Spraying a small amount of contact cleaner into that space and rolling the control stick around can potentially fix the issue. Otherwise, the problem may lie with the potentiometer inside the controller.
A small amount of contact cleaner directly in the potentiometer may work, otherwise they will need to be replaced. Follow this guide up to Step 2 to open up the Duke controller and separate the two halves.
    1. Xbox Duke Controller Potentiometer Replacement, Face Plate: step 1, image 1 of 3 Xbox Duke Controller Potentiometer Replacement, Face Plate: step 1, image 2 of 3 Xbox Duke Controller Potentiometer Replacement, Face Plate: step 1, image 3 of 3
      • Remove the seven black 8 mm screws holding the two halves of the Duke together using a Phillips #1 screwdriver.
      • To reach the deeply set screws, use a longer screw driver or a 4.0 socket bit in addition to the PH1 bit.
      Ask FixBot
    2. Xbox Duke Controller Potentiometer Replacement: step 2, image 1 of 3 Xbox Duke Controller Potentiometer Replacement: step 2, image 2 of 3 Xbox Duke Controller Potentiometer Replacement: step 2, image 3 of 3
      • Remove the two halves of the Duke, placing the top plate face-down so the buttons don't fall out.
      Ask FixBot
    1. Xbox Duke Controller Potentiometer Replacement, Potentiometer: step 3, image 1 of 2 Xbox Duke Controller Potentiometer Replacement, Potentiometer: step 3, image 2 of 2
      • Remove the stick caps from the potentiometers.
      Ask FixBot
    2. Xbox Duke Controller Potentiometer Replacement: step 4, image 1 of 2 Xbox Duke Controller Potentiometer Replacement: step 4, image 2 of 2
      • Disconnect the connectors attaching the rumble motors to the motherboard using a pair of tweezers.
      • Be gentle when slipping the tweezers underneath the flaps of the connectors; they are fragile and can snap.
      Ask FixBot
    3. Xbox Duke Controller Potentiometer Replacement: step 5, image 1 of 2 Xbox Duke Controller Potentiometer Replacement: step 5, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the four yellow 8 mm screws holding the motherboard to the bottom half of the controller.
      Ask FixBot
    4. Xbox Duke Controller Potentiometer Replacement: step 6, image 1 of 2 Xbox Duke Controller Potentiometer Replacement: step 6, image 2 of 2
      • Remove the motherboard from the bottom half of the controller.
      Ask FixBot
    5. Xbox Duke Controller Potentiometer Replacement: step 7, image 1 of 3 Xbox Duke Controller Potentiometer Replacement: step 7, image 2 of 3 Xbox Duke Controller Potentiometer Replacement: step 7, image 3 of 3
      • Desolder the connector pins holding the left trigger assembly in place.
      • Remove the trigger assembly by pushing on the black connectors that hold them to the motherboard.
      Ask FixBot
    6. Xbox Duke Controller Potentiometer Replacement: step 8, image 1 of 1
      • Desolder all of the connector pins holding the potentiometer in place.
      • Pull out the potentiometers and solder the new ones into place.
      Ask FixBot
Author
with
Anthony Casino
678 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 27
Past 30 Days: 132
All Time: 1,289
