Up to 20% off select tools
Xbox Disassembly
Views: 233K
View statistics:
Past 24 Hours:
52
Past 7 Days:
335
Past 30 Days:
1,514
All Time:
232,867
Comments: 23
12 comments on steps, 11 guide comments.
Go to guide comments
Completed: 59
59 people have marked this guide "completed." Will you be next?
Favorites: 155
155 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Xbox Disassembly
Tools
Introduction
Go to step 1 ↓
This is the teardown for the original Microsoft Xbox, not the Xbox 360.
Video Overview
    1. Xbox Disassembly, Console: step 1, image 1 of 1
      • Start with your Xbox unplugged and sitting on a flat, stable surface.
      Ask FixBot
    2. Xbox Disassembly: step 2, image 1 of 1
      • Flip the Xbox over and pry off the rubber feet with a metal spudger.
      Ask FixBot
    3. Xbox Disassembly: step 3, image 1 of 2 Xbox Disassembly: step 3, image 2 of 2
      • Peel back both the silver sticker and the white barcode sticker to reveal two additional screws.
      Ask FixBot
    4. Xbox Disassembly: step 4, image 1 of 1
      • Use a T20 Torx screwdriver to remove the four screws located under the rubber feet you just removed as well as the two screws from beneath the stickers removed in the previous step.
      Ask FixBot
    5. Xbox Disassembly: step 5, image 1 of 2 Xbox Disassembly: step 5, image 2 of 2
      • Once the bottom shell is no longer attached, carefully turn the Xbox right-side-up and lift off the top shell.
      Ask FixBot
    6. Xbox Disassembly: step 6, image 1 of 2 Xbox Disassembly: step 6, image 2 of 2
      • Move the grey ribbon cable out of the way in order to remove the three 3 mm screws using T10 Torx screwdriver. They are located on the upper right corner, lower right, and lower left corners of disk drive.
      • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
      Ask FixBot
    7. Xbox Disassembly: step 7, image 1 of 2 Xbox Disassembly: step 7, image 2 of 2
      • Lift the hard drive storage unit out of the Xbox. It should come right out.
      • Take the power cable out of the track around the hard drive so that the unit will come out easier.
      Ask FixBot
    8. Xbox Disassembly: step 8, image 1 of 3 Xbox Disassembly: step 8, image 2 of 3 Xbox Disassembly: step 8, image 3 of 3
      • Use a T15 Torx screwdriver to remove four 3.37mm screws from both sides of the hard drive.
      • Remove the plastic housing from the hard drive. It does have some clips on it, but it should come right off.
      Ask FixBot
    9. Xbox Disassembly: step 9, image 1 of 2 Xbox Disassembly: step 9, image 2 of 2
      • Unplug both the ribbon cable and power cable from hard drive.
      • They are in there pretty tightly, so this may take some effort.
      Ask FixBot
    10. Xbox Disassembly: step 10, image 1 of 3 Xbox Disassembly: step 10, image 2 of 3 Xbox Disassembly: step 10, image 3 of 3
      • Remove the disk drive. It should come right out.
      • Unplug the ribbon cable and yellow cables from back of disk drive.
      Ask FixBot
    11. Xbox Disassembly: step 11, image 1 of 1
      • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
      Ask FixBot
    12. Xbox Disassembly: step 12, image 1 of 1
      • Unplug the multi-colored power cord from the motherboard. It can be plugged in very tight, so it may take some effort to unplug it.
      Ask FixBot
    13. Xbox Disassembly: step 13, image 1 of 2 Xbox Disassembly: step 13, image 2 of 2
      • Using T10 Torx screwdriver, remove two 3mm screws from the power supply board.
      Ask FixBot
    14. Xbox Disassembly: step 14, image 1 of 2 Xbox Disassembly: step 14, image 2 of 2
      • Remove the power supply and set it aside. It should lift right out.
      Ask FixBot
    15. Xbox Disassembly: step 15, image 1 of 2 Xbox Disassembly: step 15, image 2 of 2
      • Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard.
      Ask FixBot
    16. Xbox Disassembly: step 16, image 1 of 2 Xbox Disassembly: step 16, image 2 of 2
      • Remove eleven 3mm screws from motherboard, using a T10 Torx screwdriver. Refer to the picture to find all eleven.
      • Unplug the power cable attached to the fan.
      Ask FixBot
    17. Xbox Disassembly: step 17, image 1 of 1
      • Remove the motherboard from the Xbox. As long as all of the screws are out and the fan is disconnected, it will lift out easily.
      Ask FixBot
    18. Xbox Disassembly: step 18, image 1 of 1
      • Pry the plastic fan clips away from the fan base and remove the fan.
      • This may take a little effort, as the clips are pretty stiff. Beware, the fan will be filthy.
      Ask FixBot
    19. Xbox Disassembly: step 19, image 1 of 2 Xbox Disassembly: step 19, image 2 of 2
      • Using a T10 Torx screwdriver, remove two 3mm screws from each of two controller sockets.
      • Take the sockets out by pulling back and up at the same time.
      Ask FixBot
    20. Xbox Disassembly: step 20, image 1 of 1
      • Congratulations, your Xbox is now completely dismembered.
      Ask FixBot
59 other people completed this guide.
Author
with
rmarstel
6,378 Reputation
5 Guides authored
Cal Poly, Team 18-2, Maness Fall 2009 Member of Cal Poly, Team 18-2, Maness Fall 2009
CPSU-MANESS-F09S18G2
3 Members
60 Guides authored
11 Guide Comments
Awesomeness, thanks a lot!
godoyander - Reply Share
Thanks a million - perfect!
xan_lucky16 - Reply Share
Heatsink removal?
Matt Russell - Reply Share
Face plate removal?
Herberth Alvarez - Reply Share
Did a complete cleanup and refresh of my Xbox thanks to your guide, thank you :)
Mickaël STEMMER - Reply Share
Past 24 Hours: 52
Past 7 Days: 335
Past 30 Days: 1,514
All Time: 232,867
