Xbox 360 Wireless Speed Wheel Back Panel Replacement
    1. Xbox 360 Wireless Speed Wheel Back Panel Replacement, Battery: step 1, image 1 of 2 Xbox 360 Wireless Speed Wheel Back Panel Replacement, Battery: step 1, image 2 of 2
      • Turn the controller on its backside and push the "eject" button to discharge the battery compartment door on the bottom of the controller.
      • Pull the two AA batteries out.
      Ask FixBot
    1. Xbox 360 Wireless Speed Wheel Back Panel Replacement, Back Panel: step 2, image 1 of 2 Xbox 360 Wireless Speed Wheel Back Panel Replacement, Back Panel: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the holographic Microsoft sticker with the percision tweezers to reveal a small screw.
      • Use a T6 Torx screwdriver to remove the 1.5mm screw.
      Ask FixBot
    2. Xbox 360 Wireless Speed Wheel Back Panel Replacement: step 3, image 1 of 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: step 3, image 2 of 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: step 3, image 3 of 3
      • Insert a spudger and pry at these three locations to detach the middle cover.
      • Pull off the middle piece cover to reveal three screws.
      • Use a T8 Torx screwdriver to remove the three 2.3mm screws.
      • Remove the cover.
      Ask FixBot
    3. Xbox 360 Wireless Speed Wheel Back Panel Replacement: step 4, image 1 of 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: step 4, image 2 of 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: step 4, image 3 of 3
      • Remove the two 90mm screws with a T8 Torx screwdriver.
      • Lift up the silver middle piece to remove.
      Ask FixBot
    4. Xbox 360 Wireless Speed Wheel Back Panel Replacement: step 5, image 1 of 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: step 5, image 2 of 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: step 5, image 3 of 3
      • Use a spudger to remove the silver prong.
      • With the spudger, pinch the metal spring and slowly pull up to remove.
      • Use the spudger to remove eject button.
      • Remove the screw holding in the eject button with a T8 Torx screwdriver.
      Ask FixBot
    5. Xbox 360 Wireless Speed Wheel Back Panel Replacement: step 6, image 1 of 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: step 6, image 2 of 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: step 6, image 3 of 3
      • This step is very difficult and may require a third hand.
      • Pull the two halves apart at the bottom to detach the two latches that are holding the front and back panels together.
      • Start with one side of the controller (left or right).
      • Slide the spudger towards the end of the handles and pry the two halves apart. Do the same for the opposite side.
      • The white circular caps at the top of the controller will pop off by applying light force.
      • Pull the front and back panels apart to separate them and expose the inside of the controller.
      Ask FixBot
lauren paganella
485 Reputation
4 Guides authored
USF Tampa, Team S16-G5, Boczar Spring 2018 Member of USF Tampa, Team S16-G5, Boczar Spring 2018
USFT-BOCZAR-S18S16G5
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 43
All Time: 1,658
