Xbox 360 Wireless Controller Vibration Motors Replacement
  1. Xbox 360 Wireless Controller Vibration Motors Replacement, Battery: step 1, image 1 of 2 Xbox 360 Wireless Controller Vibration Motors Replacement, Battery: step 1, image 2 of 2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
    Ask FixBot
  2. Xbox 360 Wireless Controller Vibration Motors Replacement, Rear Case: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
    Ask FixBot
  3. Xbox 360 Wireless Controller Vibration Motors Replacement: step 3, image 1 of 1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
    Ask FixBot
  4. Xbox 360 Wireless Controller Vibration Motors Replacement: step 4, image 1 of 2 Xbox 360 Wireless Controller Vibration Motors Replacement: step 4, image 2 of 2
    Spudger
    $2.99
    Buy
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
    Ask FixBot
  5. Xbox 360 Wireless Controller Vibration Motors Replacement: step 5, image 1 of 2 Xbox 360 Wireless Controller Vibration Motors Replacement: step 5, image 2 of 2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
    Ask FixBot
  6. Xbox 360 Wireless Controller Vibration Motors Replacement: step 6, image 1 of 2 Xbox 360 Wireless Controller Vibration Motors Replacement: step 6, image 2 of 2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
    Ask FixBot
  7. Xbox 360 Wireless Controller Vibration Motors Replacement, Vibration Motors: step 7, image 1 of 2 Xbox 360 Wireless Controller Vibration Motors Replacement, Vibration Motors: step 7, image 2 of 2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
    Ask FixBot
  8. Xbox 360 Wireless Controller Vibration Motors Replacement: step 8, image 1 of 2 Xbox 360 Wireless Controller Vibration Motors Replacement: step 8, image 2 of 2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
    Ask FixBot
20 other people completed this guide.
Brett Hartt
132,230 Reputation
144 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,603 Guides authored
3 Guide Comments
Hello, I am very concerned about which side of the controller the motor with heavier counterweight should be. Shouldn’t it be on the left side of the controller, since the right side should be used for higher frequency vibrations?
Yado Nada - Reply Share
Hi Yado,
Thanks for pointing this out! You are right—the left side have the heavier counterweight. I’ve corrected the relevant step.
Arthur Shi - Reply Share
Hi there, I believe that the screenshots provided have the vibration motors on the wrong sides. Watching several videos of the disassembly on youtube as well as taking apart my own controller that previously was never opened, the larger heavier motor should be on the right side and the smaller lighter motor should be on the left side.
Salman Kazi - Reply Share
Past 24 Hours: 9
Past 7 Days: 50
Past 30 Days: 199
All Time: 40,874
