Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Spudger4.9
Introduction
Go to step 1 ↓Fire away by replacing the triggers on your Xbox 360 Wireless Controller.
Depress the battery release button on the top of the controller.
Remove the battery holder from the controller.
Tool used on this step:Tweezers$4.99
Use a pair of tweezers to peel the barcode sticker from the battery compartment.
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
Lift the vibration motor out of the front case.
Lifting from the headphone jack and power plug, remove the logic board from the front case.
Using your thumb and forefinger, push the left trigger toward the right side of the controller. Simultaneously push the trigger control arm in the opposite direction.
Push the trigger arm downward.
Insert the edge of a spudger in between the trigger and the trigger assembly near the left edge. Pry the housing away from the catch on the trigger.
Using the previously described technique, pry the housing on the right edge away from the trigger.
Rotate the trigger away from the logic board, past its housing.
47 other people completed this guide.
5 Guide Comments
use a small tag of double sided tape to hold the counterweights in when you rebuild or its nearly impossible to tip up the two halfs of the controller to fit them together. With the counterweight just slightly stuck into place with a tiny tag of double sided tape you can tip that half of the controller upside down to fit on top of the other half. Still awkward but do-able. Almost impossible otherwise.
If i leave out the vibrations things will it cause the problems tonthe board ??
These instructions were given in proper order and understanding
IMO this could have benefited from some instructions on how to get the triggers back on, cause it was quite a challenge.
The way I managed to do it, is you've got to reverse both step 11 and step 10 in one go, otherwise it would be impossible to get the trigger peg into the white arm (at least I couldn't figure out a way to do it): before reversing step 11, hold the white arm up and to same side you pushed it in the step 10, and then once you click it back into place, the peg would also go into the slot in the arm. For me it was easier to do for LT than RT - the latter too a few tries, so I would recommend doing LT first and then RT.
