Up to 20% off select tools
Xbox 360 Wireless Controller Bottom Panel Replacement
Views: 21K
View statistics:
Past 24 Hours:
6
Past 7 Days:
42
Past 30 Days:
159
All Time:
20,532
Comments: 15
13 comments on steps, 2 guide comments.
Go to guide comments
Completed: 20
20 people have marked this guide "completed." Will you be next?
Favorites: 28
28 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the bottom panel of your controller that you cracked by throwing it at the TV.
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Battery: step 1, image 1 of 2 Xbox 360 Wireless Controller Bottom Panel Replacement, Battery: step 1, image 2 of 2
      • Depress the battery release button on the top of the controller.
      • Remove the battery holder from the controller.
      • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
      Ask FixBot
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Rear Case: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
      Ask FixBot
    2. Xbox 360 Wireless Controller Bottom Panel Replacement: step 3, image 1 of 1
      • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
      Ask FixBot
    3. Xbox 360 Wireless Controller Bottom Panel Replacement: step 4, image 1 of 2 Xbox 360 Wireless Controller Bottom Panel Replacement: step 4, image 2 of 2
      Spudger
      $2.99
      Buy
      • Insert a Spudger between the front and rear cases along the left edge of the controller.
      • Rotate the spudger toward the front of the controller, prying the two cases apart.
      Ask FixBot
    4. Xbox 360 Wireless Controller Bottom Panel Replacement: step 5, image 1 of 2 Xbox 360 Wireless Controller Bottom Panel Replacement: step 5, image 2 of 2
      • Insert a spudger between the front and rear cases, near the headphone jack.
      • Rotate the spudger toward the front of the controller to pry the two cases apart.
      Ask FixBot
    5. Xbox 360 Wireless Controller Bottom Panel Replacement: step 6, image 1 of 2 Xbox 360 Wireless Controller Bottom Panel Replacement: step 6, image 2 of 2
      • Grasp the controller by the battery compartment and the headphone jack.
      • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
      • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
      Ask FixBot
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Vibration Motors: step 7, image 1 of 2 Xbox 360 Wireless Controller Bottom Panel Replacement, Vibration Motors: step 7, image 2 of 2
      • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
      • Lift the vibration motor out of the front case.
      Ask FixBot
    2. Xbox 360 Wireless Controller Bottom Panel Replacement: step 8, image 1 of 2 Xbox 360 Wireless Controller Bottom Panel Replacement: step 8, image 2 of 2
      • Remove the vibration motor from the other side of the controller using the same method previously described.
      • The left motor has significantly more counterweight than the right motor.
      Ask FixBot
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Logic Board: step 9, image 1 of 2 Xbox 360 Wireless Controller Bottom Panel Replacement, Logic Board: step 9, image 2 of 2
      • Lifting from the headphone jack and power plug, remove the logic board from the front case.
      Ask FixBot
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Bottom Panel: step 10, image 1 of 2 Xbox 360 Wireless Controller Bottom Panel Replacement, Bottom Panel: step 10, image 2 of 2
      • Lift the bumper panel off of the front case.
      Ask FixBot
    2. Xbox 360 Wireless Controller Bottom Panel Replacement: step 11, image 1 of 1
      • Remove the rubber pad from the back of the D-pad.
      Ask FixBot
    3. Xbox 360 Wireless Controller Bottom Panel Replacement: step 12, image 1 of 1
      • Remove the two 7.0 mm silver Phillips screws from the back of the D-pad.
      Ask FixBot
    4. Xbox 360 Wireless Controller Bottom Panel Replacement: step 13, image 1 of 2 Xbox 360 Wireless Controller Bottom Panel Replacement: step 13, image 2 of 2
      Buy
      • The D-pad is secured to its backing by two diagonal clips, shown in red.
      • Use a pair of tweezers and squeeze the clips together to release the D-pad from its backing.
      Ask FixBot
    5. Xbox 360 Wireless Controller Bottom Panel Replacement: step 14, image 1 of 2 Xbox 360 Wireless Controller Bottom Panel Replacement: step 14, image 2 of 2
      • Lift the D-pad backing out of its compartment on the front case.
      • The D-pad remains below the front case.
      • The D-pad will fall once its backing is removed. Be sure to support it as you remove the backing.
      • The backing is slotted to its compartment to ensure that it will always be aligned properly.
      Ask FixBot
    6. Xbox 360 Wireless Controller Bottom Panel Replacement: step 15, image 1 of 1
      • Remove the rubber pad from the back of the input buttons.
      Ask FixBot
    7. Xbox 360 Wireless Controller Bottom Panel Replacement: step 16, image 1 of 2 Xbox 360 Wireless Controller Bottom Panel Replacement: step 16, image 2 of 2
      • Using a pair or tweezers, remove the following buttons from the front panel:
      • A Button
      • B Button
      • X Button
      • Y Button
      • Start Button
      • Select Button
      • Guide Button
      Ask FixBot
    8. Xbox 360 Wireless Controller Bottom Panel Replacement: step 17, image 1 of 1
      • Using a pair of tweezers, remove the LED ring from the front panel.
      Ask FixBot
    9. Xbox 360 Wireless Controller Bottom Panel Replacement: step 18, image 1 of 3 Xbox 360 Wireless Controller Bottom Panel Replacement: step 18, image 2 of 3 Xbox 360 Wireless Controller Bottom Panel Replacement: step 18, image 3 of 3
      • Insert a spudger between the lower panel and front case.
      • Slide the spudger along the gap between the two case components.
      • Lift the lower panel off of the front case.
      Ask FixBot
20 other people completed this guide.
Author
with
Brett Hartt
132,682 Reputation
144 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
2 Guide Comments
I have 2 remote controllers of X box one which is not working.
ravi.gopalakrishnan - Reply Share
Ib rb button
Abdou Fegas - Reply Share
Past 24 Hours: 6
Past 7 Days: 42
Past 30 Days: 159
All Time: 20,532
