Xbox 360 S Wi-Fi Board Replacement
    1. Xbox 360 S Wi-Fi Board Replacement, Top Panel: step 1, image 1 of 1
      • In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
      • Take care when removing the fan vent not to break any of the plastic clips.
      Ask FixBot
    2. Xbox 360 S Wi-Fi Board Replacement: step 2, image 1 of 2 Xbox 360 S Wi-Fi Board Replacement: step 2, image 2 of 2
      • Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
      • Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
      • Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
      • Be sure to rotate the spudger far enough so that the plastic clips clear the silver rim of the top bezel.
      Ask FixBot
    3. Xbox 360 S Wi-Fi Board Replacement: step 3, image 1 of 3 Xbox 360 S Wi-Fi Board Replacement: step 3, image 2 of 3 Xbox 360 S Wi-Fi Board Replacement: step 3, image 3 of 3
      • Insert a metal spudger between the fan vent and top bezel along the left side of the console.
      • In the same manner described above, begin prying the left side of the top vent away from the top bezel.
      • Continue prying along the left side of the device, freeing all the clips on that side.
      Ask FixBot
    4. Xbox 360 S Wi-Fi Board Replacement: step 4, image 1 of 2 Xbox 360 S Wi-Fi Board Replacement: step 4, image 2 of 2
      • Lift the fan vent up from the freed left side to disengage the clips along the right side.
      • Remove the entire fan vent.
      Ask FixBot
    5. Xbox 360 S Wi-Fi Board Replacement: step 5, image 1 of 2 Xbox 360 S Wi-Fi Board Replacement: step 5, image 2 of 2
      • In the following steps, you will be releasing the six clips highlighted in red.
      • Each clip can be undone by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
      Ask FixBot
    6. Xbox 360 S Wi-Fi Board Replacement: step 6, image 1 of 2 Xbox 360 S Wi-Fi Board Replacement: step 6, image 2 of 2
      • Orient the console so that the left case is facing toward you and the faceplate is facing toward the right.
      • Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
      • Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
      • You will hear a "pop" signifying that the clip cleared its catch.
      Ask FixBot
    7. Xbox 360 S Wi-Fi Board Replacement: step 7, image 1 of 2 Xbox 360 S Wi-Fi Board Replacement: step 7, image 2 of 2
      • Using the same method described above, free the two remaining clips along the left edge of the top bezel.
      Ask FixBot
    8. Xbox 360 S Wi-Fi Board Replacement: step 8, image 1 of 1
      • Grab the entire top panel with your hands, lift up the entire left edge high enough to rest the separated clips on top of the left case.
      • You may have to go back with a spudger and undo any clips that have re-attached.
      • The top panel will not come free of the console yet.
      Ask FixBot
    9. Xbox 360 S Wi-Fi Board Replacement: step 9, image 1 of 2 Xbox 360 S Wi-Fi Board Replacement: step 9, image 2 of 2
      • Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
      • Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
      • While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
      Ask FixBot
    10. Xbox 360 S Wi-Fi Board Replacement: step 10, image 1 of 2 Xbox 360 S Wi-Fi Board Replacement: step 10, image 2 of 2
      • In the same manner as described in the previous steps, release the middle and front clips along the right edge of the top panel.
      Ask FixBot
    11. Xbox 360 S Wi-Fi Board Replacement: step 11, image 1 of 1
      • Lift the top panel off the device.
      • You may have to go back with a spudger and undo any clips that have re-attached to the console.
      Ask FixBot
    1. Xbox 360 S Wi-Fi Board Replacement, Wi-Fi Board: step 12, image 1 of 3 Xbox 360 S Wi-Fi Board Replacement, Wi-Fi Board: step 12, image 2 of 3 Xbox 360 S Wi-Fi Board Replacement, Wi-Fi Board: step 12, image 3 of 3
      • Remove the single T10 Torx screw holding in the wireless card.
      • Pull the Wi-Fi board out of the console.
      Ask FixBot
40 other people completed this guide.
Brett Hartt
132,418 Reputation
144 Guides authored
iFixit Member of iFixit
Staff
123 Members
86,246 Guides authored
6 Guide Comments
My Slim came without the wifi board, and subsequently without the holding screw.
Anyone know the thread, size, or depth of a replacement screw I could use to hold the replacement in? It seems like it won't go anywhere with the pseudo-USB connector in place, but I'd like to be positive.
Any help would be appreciated!
mattinnihon - Reply Share
Tuve ese mismo problema. Fui a una tienda y el técnico tuvo que quitarle la tarjeta de WiFi a otro xbox porque no hay repuesto
andreshgarcia20 - Reply Share
Worth noting.. Before you purchase a new wifi card, try taking it out and reseating it. Just had to do that with mine when the wifi suddenly stopped working. Once I pulled the card and put it back in, it worked beautifully.
Also, for clarification, you are opening the side OPPOSITE the side with the hard drive.
sarncadrill - Reply Share
Is it possible to replace it a newer, updated, improved WiFi card that is faster?
NoraTheSuccubus - Reply Share
My x box 360 didn’t come with Wi-Fi chip so what do I need to use my box online anyone please ?
Yusif yahiya Abdul Kareem - Reply Share
Past 24 Hours: 9
Past 7 Days: 72
Past 30 Days: 226
All Time: 61,902
