Up to 20% off select tools
Xbox 360 S Panel removal
Views: 4.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
47
Past 30 Days:
194
All Time:
4,587
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide will explain how to remove the Hard Drive, take apart the Bottom Panel, and the Top Panel.
    1. Xbox 360 S Panel removal, Hard Drive: step 1, image 1 of 3 Xbox 360 S Panel removal, Hard Drive: step 1, image 2 of 3 Xbox 360 S Panel removal, Hard Drive: step 1, image 3 of 3
      • Flip the Xbox over and you will see three separate prongs. Pull those back and pull up, then you will see the hard drive. Pull the rectangle fabric piece up.
      • The hard drive should be removed.
      Ask FixBot
    2. Xbox 360 S Panel removal, Bottom Panel: step 2, image 1 of 3 Xbox 360 S Panel removal, Bottom Panel: step 2, image 2 of 3 Xbox 360 S Panel removal, Bottom Panel: step 2, image 3 of 3
      • Move the Xbox with the hard drive facing toward the right.
      • Then insert your Metal Spudger in between the silver ring and the vent. You should here a pop noise which is the clip popping out.
      • Rotate the tool away from the Xbox prying open the bottom plate. Continue that step for all the remaining clips.
      Ask FixBot
    3. Xbox 360 S Panel removal, Top Panel: step 3, image 1 of 3 Xbox 360 S Panel removal, Top Panel: step 3, image 2 of 3 Xbox 360 S Panel removal, Top Panel: step 3, image 3 of 3
      • The top panel is very similar to the bottom panel removal. There will be thirteen clips you need to undo.
      • Make sure the front of the Xbox is facing towards the left. Then use the tool undo the clips just like you did on the bottom panel.
      • DO NOT BREAK ANY OF THE CLIPS.
      Ask FixBot
Finish Line
6 other people completed this guide.
Author
with
Jack Sweet
286 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 47
Past 30 Days: 194
All Time: 4,587
