Xbox 360 S Hard Drive Replacement
    1. Xbox 360 S Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 Xbox 360 S Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 Xbox 360 S Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
      • Orient the Xbox 360 S so that the bottom of the console is facing toward you.
      • Push the latch holding down the hard drive cover to the left.
      • Pull the hard drive cover away from the console.
      Ask FixBot
    2. Xbox 360 S Hard Drive Replacement: step 2, image 1 of 3 Xbox 360 S Hard Drive Replacement: step 2, image 2 of 3 Xbox 360 S Hard Drive Replacement: step 2, image 3 of 3
      • Firmly grasp the fabric tab labeled with the size of the hard drive (e.g. "250 GB") attached to the hard drive.
      • Pull the hard drive straight out of the console.
      • The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
      Ask FixBot
112 other people completed this guide.
Brett Hartt
132,360 Reputation
144 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
5 Guide Comments
do you have to transfer the OS? or data? if so what utility is used? do you need a data transfer cable?
Can I just add an external drive to supplement the existing HDD?
David Johnson - Reply Share
no the os is on the internal drive all the hard drive is doing is adding more storge space
Nightwolf Gamer - Reply Share
My hardrive says its unformated but its not and i dont want to loose content
Javier Eduardo Pacheco Hazim - Reply Share
Can I take the external out of the little black cover?
Lallie Cooney - Reply Share
Will it play backwards compatible games
justin rzonca - Reply Share
Past 24 Hours: 25
Past 7 Days: 146
Past 30 Days: 656
All Time: 164,847
