Community-Contributed Guide
Parts
Introduction
Go to step 1 ↓The Xbox 360 is getting old, and with that more problems will start to happen to these aging systems. This guide outlines preventative maintenance you can do to extend the life of your Xbox 360, from least difficult to most.
The DVD drive belt, which allows the DVD drive to open when the motor spins, stretches and becomes misshapen over time, eventually stopping the drive from opening.
With how old the Xbox 360 is now, it may not be long before your drive belt stretches and becomes misshapen.
Follow this guide to replace it.
All electronics with a fan (or even without one) collect dust over time.
This dust can eventually clog the heatsinks and/or fans, causing your Xbox 360 to be noisy or overheat.
Follow this guide up to (and including) step 35. Clean the fans, motherboard, and all of the casing with high purity (90+%) isopropyl alcohol, and blow out the dust from the heat sinks with compressed air. Then reassemble your Xbox 360.
55 other people completed this guide.
5 Guide Comments
This guide should have steps and cover a single topic. You should split this guide in two, one for how to store the Xbox in a well ventilated area (not just examples, but directions) and another for how to clean the heat sink. The best guides can be referenced in any context and are detailed instructions to reach a goal, as opposed to guidelines or examples of proper use. Good idea though, preventing issues is better than solving them!
Good points made by Alex.
Most obviously, where should you blow into the xbox to clear out the dust? A couple red circles around the best holes to stick the straw into to blow out the dust would be very helpful.
One should also take into consideration that dust and overheating are not truly the cause of a RRoD error unless it's simply overheating. I've reballed plenty on consoles, as new as 2009, with no dust whatsoever in the system. I've also done tray cleaning and lubrication on consoles that were filled with thick layers of dust without ever red ringing.
