Xbox 360 E Wi-Fi Card Replacement
    1. Xbox 360 E Wi-Fi Card Replacement, Top Panel: step 1, image 1 of 1
      • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
      • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
      Ask FixBot
    2. Xbox 360 E Wi-Fi Card Replacement: step 2, image 1 of 1
      • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
      • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
      Ask FixBot
    3. Xbox 360 E Wi-Fi Card Replacement: step 3, image 1 of 3 Xbox 360 E Wi-Fi Card Replacement: step 3, image 2 of 3 Xbox 360 E Wi-Fi Card Replacement: step 3, image 3 of 3
      • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
      • Pull the top panel off.
      Ask FixBot
    1. Xbox 360 E Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 1 of 1
      • Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
      Ask FixBot
    2. Xbox 360 E Wi-Fi Card Replacement: step 5, image 1 of 2 Xbox 360 E Wi-Fi Card Replacement: step 5, image 2 of 2
      • Firmly grip the green Wi-Fi card and pull it out of the Xbox.
      Ask FixBot
8 other people completed this guide.
Jennifer
2,293 Reputation
4 Guides authored
Cal Poly, Team 2-11, Amido Winter 2014 Member of Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Members
132 Guides authored
1 Guide Comment
Nicely done!
dakota.1970 - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 128
All Time: 13,288
