Xbox 360 E CD Drive Replacement
Views: 29K
View statistics:
Past 24 Hours:
10
Past 7 Days:
77
Past 30 Days:
353
All Time:
28,894
Comments: 23
11 comments on steps, 12 guide comments.
Go to guide comments
Completed: 28
28 people have marked this guide "completed." Will you be next?
Favorites: 28
28 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Following this guide involves opening the Xbox 360 E and is somewhat more involved than replacing other parts of the Xbox.
Tools
  • Spudger
    4.9
    1. Xbox 360 E CD Drive Replacement, Top Panel: step 1, image 1 of 1
      • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
      • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
      Ask FixBot
    2. Xbox 360 E CD Drive Replacement: step 2, image 1 of 1
      • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
      • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
      Ask FixBot
    3. Xbox 360 E CD Drive Replacement: step 3, image 1 of 3 Xbox 360 E CD Drive Replacement: step 3, image 2 of 3 Xbox 360 E CD Drive Replacement: step 3, image 3 of 3
      • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
      • Pull the top panel off.
      Ask FixBot
    1. Xbox 360 E CD Drive Replacement, Wi-Fi Card: step 4, image 1 of 1
      • Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
      Ask FixBot
    2. Xbox 360 E CD Drive Replacement: step 5, image 1 of 2 Xbox 360 E CD Drive Replacement: step 5, image 2 of 2
      • Firmly grip the green Wi-Fi card and pull it out of the Xbox.
      Ask FixBot
    1. Xbox 360 E CD Drive Replacement, Bottom Panel: step 6, image 1 of 1
      • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
      • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
      Ask FixBot
    2. Xbox 360 E CD Drive Replacement: step 7, image 1 of 2 Xbox 360 E CD Drive Replacement: step 7, image 2 of 2
      • Slide the spudger along the crevice to separate the grated face and the top body.
      Ask FixBot
    3. Xbox 360 E CD Drive Replacement: step 8, image 1 of 3 Xbox 360 E CD Drive Replacement: step 8, image 2 of 3 Xbox 360 E CD Drive Replacement: step 8, image 3 of 3
      • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
      • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
      • Pull the bottom panel off.
      Ask FixBot
    1. Xbox 360 E CD Drive Replacement, Top Body: step 9, image 1 of 2 Xbox 360 E CD Drive Replacement, Top Body: step 9, image 2 of 2
      • Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver.
      • Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
      Ask FixBot
    1. Xbox 360 E CD Drive Replacement, Bottom Body: step 10, image 1 of 3 Xbox 360 E CD Drive Replacement, Bottom Body: step 10, image 2 of 3 Xbox 360 E CD Drive Replacement, Bottom Body: step 10, image 3 of 3
      • Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
      • Lift the bottom body slightly away from the core at a 45 degree angle.
      Ask FixBot
    2. Xbox 360 E CD Drive Replacement: step 11, image 1 of 2 Xbox 360 E CD Drive Replacement: step 11, image 2 of 2
      • Rotate the Xbox so you are now looking at the back of the device.
      • This step of disassembly requires the removal of the warranty sticker. This will void your warranty. Check the main page for a link to warranty information from Microsoft.
      • Remove the sticker from the back of the Xbox.
      • The sticker is not needed for reassembly.
      Ask FixBot
    3. Xbox 360 E CD Drive Replacement: step 12, image 1 of 3 Xbox 360 E CD Drive Replacement: step 12, image 2 of 3 Xbox 360 E CD Drive Replacement: step 12, image 3 of 3
      • Turn the Xbox to the left to locate the clip holding the body together.
      • With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way.
      Ask FixBot
    4. Xbox 360 E CD Drive Replacement: step 13, image 1 of 2 Xbox 360 E CD Drive Replacement: step 13, image 2 of 2
      • Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this.
      Ask FixBot
    1. Xbox 360 E CD Drive Replacement, CD Drive: step 14, image 1 of 2 Xbox 360 E CD Drive Replacement, CD Drive: step 14, image 2 of 2
      • Use your fingers to unplug the blue ribbon cable from the CD drive.
      Ask FixBot
    2. Xbox 360 E CD Drive Replacement: step 15, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to unplug the blue and pink wires.
      Ask FixBot
    3. Xbox 360 E CD Drive Replacement: step 16, image 1 of 1
      • Lift the front end of the CD drive and take it out.
      Ask FixBot
28 other people completed this guide.
George
671 Reputation
1 Guide authored
Cal Poly, Team 2-11, Amido Winter 2014 Member of Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Members
132 Guides authored
12 Guide Comments
i wish the bottom cover magically came off like in step 9
sandjo - Reply Share
screws are actually C1- C5 one is incorrectly labelled - C7 = C1 also in step 8.5 there are 3 clips holding back edge of bottom cover to top one. one on each end and one just to right of I/O area. can get 2 of them with a spudger (ends) and the middle one with a isesamo.
Andrew Boyd - Reply Share
Several steps missing between 8 and 9
Freddie Parsons - Reply Share
Like remove wifi adaptor.
william capewell - Reply Share
There is some consistency errors in this guide. Step 9 seems to blast ahead beyond where we should be at this point of the guide.
Joe G. - Reply Share
Past 24 Hours: 10
Past 7 Days: 77
Past 30 Days: 353
All Time: 28,894
