XQ-673H Water Tubes Replacement
    1. XQ-673H Water Tubes Replacement, Water Tubes: step 1, image 1 of 1
      • Make sure the device is unplugged before continuing.
      • Turn the Kitchen Gourmet upside down.
      Ask FixBot
    2. XQ-673H Water Tubes Replacement: step 2, image 1 of 3 XQ-673H Water Tubes Replacement: step 2, image 2 of 3 XQ-673H Water Tubes Replacement: step 2, image 3 of 3
      • Using a Phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
      • Remove the bottom cover.
      Ask FixBot
    3. XQ-673H Water Tubes Replacement: step 3, image 1 of 2 XQ-673H Water Tubes Replacement: step 3, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the six 12mm screws.
      • Some screws are not visible from this photo, but their location is highlighted by the circles.
      Ask FixBot
    4. XQ-673H Water Tubes Replacement: step 4, image 1 of 3 XQ-673H Water Tubes Replacement: step 4, image 2 of 3 XQ-673H Water Tubes Replacement: step 4, image 3 of 3
      • Using small needle nose pliers, squeeze the metal that is covering the tube.
      • Carefully slide down the metal covering.
      • Repeat this step for the other tube.
      Ask FixBot
    5. XQ-673H Water Tubes Replacement: step 5, image 1 of 2 XQ-673H Water Tubes Replacement: step 5, image 2 of 2
      • Using your fingers, gently slide off the Water Tubes.
      Ask FixBot
    6. XQ-673H Water Tubes Replacement: step 6, image 1 of 2 XQ-673H Water Tubes Replacement: step 6, image 2 of 2
      • Carefully lift the bottom section off the device.
      Ask FixBot
    7. XQ-673H Water Tubes Replacement: step 7, image 1 of 2 XQ-673H Water Tubes Replacement: step 7, image 2 of 2
      • Remove both of the Water Tubes completely.
      Ask FixBot
Sean Perry
452 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 28
All Time: 1,115
