XQ-673H Power Cord Replacement
    1. XQ-673H Power Cord Replacement, Power Cord: step 1, image 1 of 1
      • Turn the Kitchen Gourmet upside down.
      • Make sure the device is unplugged before continuing.
      Ask FixBot
    2. XQ-673H Power Cord Replacement: step 2, image 1 of 3 XQ-673H Power Cord Replacement: step 2, image 2 of 3 XQ-673H Power Cord Replacement: step 2, image 3 of 3
      • Using a phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
      • Remove the bottom cover.
      Ask FixBot
    3. XQ-673H Power Cord Replacement: step 3, image 1 of 3 XQ-673H Power Cord Replacement: step 3, image 2 of 3 XQ-673H Power Cord Replacement: step 3, image 3 of 3
      • Using a Phillips #1 screwdriver, unscrew the 11mm screws.
      • Remove the plastic bar that is holding the Power Cord down.
      Ask FixBot
    4. XQ-673H Power Cord Replacement: step 4, image 1 of 2 XQ-673H Power Cord Replacement: step 4, image 2 of 2
      • Using scissors, carefully cut the zip tie.
      • Careful not to cut the Power Cord.
      Ask FixBot
    5. XQ-673H Power Cord Replacement: step 5, image 1 of 3 XQ-673H Power Cord Replacement: step 5, image 2 of 3 XQ-673H Power Cord Replacement: step 5, image 3 of 3
      • Using small needle nose pliers, gently squeeze the side so it allows the metal clamp to open up.
      • Gently pull off the plastic cover.
      • Repeat this step with the other plastic cover.
      Ask FixBot
    6. XQ-673H Power Cord Replacement: step 6, image 1 of 2 XQ-673H Power Cord Replacement: step 6, image 2 of 2
      • Remove the Power Cord from the device.
      Ask FixBot
Sean Perry
452 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 19
All Time: 562
