Parts
Tools
Introduction
Go to step 1 ↓If your Xbox Controller S joystick isn't working due to stick drift or no response, use this guide to replace the joystick (also known as the analog stick).
The joystick lets you look and move around while playing the game. Over time, these joysticks can develop stick drift, where the joystick moves in one direction even when you aren't touching it. It can also break over time due to wear and tear.
Before using this guide, if you think your controller might have stick drift, redirect yourself to our troubleshooting page.
Steps 2, 3, and 5 require you to use a soldering iron to remove the joystick from the circuit board.
This video link will be helpful in your device repair.
Remove the seven 9.4 mm screws on the back of the controller using a Phillips #00 screwdriver.
Remove the motherboard from the back shell.
Desolder the three points to the right of the joystick on the top of the motherboard.
Pry the trigger clip away from the top, then lever it downward to remove the trigger.
