X-Treme Tablet Generation 2 Motherboard Replacement
  1. X-Treme Tablet Generation 2 Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Remove the cover from the back of the tablet. Using the pick tool, pry the cover the case. Do this by starting in the upper corner, working around the edges until the cover unclips from the case.
  2. X-Treme Tablet Generation 2 Motherboard Replacement: step 2, image 1 of 1
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Find and detach all of the connections to the motherboard. Remove the connections while leaving the components in place from the battery, camera, ground wire, plastic connections at the charging port, and the 512MB DDR3 SDRAM.
    • Remove the connections using a soldering iron and desolder pump to remove the current soldered connections.
  3. X-Treme Tablet Generation 2 Motherboard Replacement: step 3, image 1 of 2 X-Treme Tablet Generation 2 Motherboard Replacement: step 3, image 2 of 2
    • Replacing the defective motherboard with a functional motherboard: Reattach the connections at the battery, camera, ground wire, plastic connections at the charging port, and the 512MB DDR3 SDRAM.
    • Reattach the connections by soldering them back onto the motherboard using a soldering iron.
Dalton Croslow
97 Reputation
1 Guide authored
IUPUI, Team S3-G3, Wilson Fall 2018 Member of IUPUI, Team S3-G3, Wilson Fall 2018
IUPUI-WILSON-F18S3G3
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 62
All Time: 481
